Manley rod Breaks
Old May 10, 2006 | 04:50 PM
96BlackPearl's Avatar
Default Manley rod Breaks
has any one ever seen a manley rod break on a honda..... on 25 psi at around 7000 to 8000 rpm in 2nd gear..... if i could put pictures of my rod i would but i hve not figured it out yet..... i will send to an email if u send me an email address
Modified by 96BlackPearl at 6:01 PM 5/10/2006
Old May 10, 2006 | 05:00 PM
Turbocivic94's Avatar
Default Re: Manley rod Breaks (96BlackPearl)
do u have any pics?
I'm running manley rods and I dont want that happen to me
Old May 10, 2006 | 05:01 PM
siblues's Avatar
I havent seen one break at that power level but then again anything can break at a certain point?What you need to worry about is why it broke?Bad tuning .bad installation or whether or not it was just a bad rod?Post up some pics and you will get a better answer to why it broke
Old May 10, 2006 | 05:02 PM
adictionbass's Avatar
Default Re: Manley rod Breaks (Turbocivic94)
send the pics to someone and have them post em
Old May 10, 2006 | 05:16 PM
Default Re: Manley rod Breaks (adictionbass)
show the pics to Erl performance and they are still trying to figure it out i have to send them moe pics..... all the other bearing look like new and it was tuned by a good tunner
.... oil pressure was good...if you want pictures email me at Civictruck88@aol.com
Modified by 96BlackPearl at 7:28 PM 5/10/2006
Old May 10, 2006 | 05:20 PM
eg crunkmonster's Avatar
ill say it broke from a bad install......or probably might have gotten a bad rod....who knows
Old May 10, 2006 | 05:23 PM
earl's Avatar
How many miles are on the motor?
Old May 10, 2006 | 05:29 PM
95GSRTT
Guest
Posts: n/a
have they recently changed the amount of ethonal in the fuel in florida? that could possibly throw off the tune.
Old May 10, 2006 | 05:34 PM
Default Re: Manley rod Breaks (95GSRTT)
it was on c16.... and the rods only had about 1000 miles
Here are pics
Old May 10, 2006 | 05:40 PM
boostedK20a2's Avatar
what fuel did you use? maybe you got bad fuel?
With Mase as the tuner.. thats a given that a bad tune has been ruled out as the problem, lol.
Old May 10, 2006 | 05:41 PM
Andrea's Avatar
What does your rod journal on your crank look like? What do the bearings from that rod look like?
We've built and tuned at least 50 or more customers engines with Manley rods without a single issue. We've also had great success with the lightweight all motor rods in N/A applications.
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
were these the "turbo" Manleys? i know they have 2 different ones..also Im no expert but that looks like a cap may have come loose and the peice that broke off the rod came from the crank smacking against it at high RPM?..?
Old May 10, 2006 | 05:42 PM
Default Re: Manley rod Breaks (Andrea)
they all look new..... no scares........
Old May 10, 2006 | 05:43 PM
Adi Radoncic's Avatar
On Fire!
Looks like "spun rod bearing gone wild" to me, but I'm no expert..
Who built the motor?
Check and see what the rod and mainly the main bearing clearances were, you had alot of heat around the big end of that rod...
Old May 10, 2006 | 05:45 PM
Default Re: Manley rod Breaks (SYD)
the rod still has a bolt screwed in it and the other side is broken off..... these were the turbo tuff manley rods..... who nows maybe it was just my luck....s**t happens
Old May 10, 2006 | 05:48 PM
B18C1CYA's Avatar
Looks to me like a bearing failed and the rod let go
Old May 10, 2006 | 05:49 PM
Default Re: Manley rod Breaks (B18C1CYA)
they were oem honda bearins
Old May 10, 2006 | 06:04 PM
Andrea's Avatar
Do you have any pics of the crank and the actual rod bearings from that journal?
Old May 10, 2006 | 06:23 PM
i guess i found a way to break them,,, not sure how though
Old May 10, 2006 | 06:29 PM
earl's Avatar
Andrea is asking the right question. Sometimes you can freeze a bearing to the crank so tightly that it actually breaks the rod because it can no longer spin with the crank. That would be much more of a builder's fault than a rod fault. The spinning crank just snaps the rod in the weakest spot. Let's not be quick to blame Manley or yourself on this.
Old May 10, 2006 | 06:38 PM
G
sh!t happens.
Default Re: Manley rod Breaks (earl)
Old May 10, 2006 | 06:41 PM
what time frame would something like this happen at
Old May 10, 2006 | 06:43 PM
Black DC2's Avatar
Default Re: Manley rod Breaks (G"UNIT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by G"UNIT &raquo;</TD></TR><TR><TD CLASS="quote">Who built the motor?</TD></TR></TABLE>
FRANCO TECH!!!!!!
Old May 10, 2006 | 06:53 PM
alpha's Avatar
Looks like a lot of discoloration on the big end. Can you get more pictures of the crank and rod bearings? Is this the black coupe that Shawn drove at Bradenton? If it was Dan said the datalog showed 10,200RPM.
