quick vacuum/boost question (searched)
Old May 9, 2006 | 07:33 PM
teg racer 877's Avatar
Default quick vacuum/boost question (searched)
I am somewhat noobish to FI and I hope this isnt to stupid but I was wondering.
does the whole vac system see the same boost that the engine is seeing? I would assume so because my boost guage is hooked up to the system via the GE vac mani, so the WG sees that same boost as well. why doesnt the vac line bulge and blow off? it seems like it would in cars pushin 15+ psi. also, I know the brake booster has a check valve but I would think the braking power would be alot less under boost cuz the valve is closed, correct?
Old May 11, 2006 | 05:13 AM
Default Re: quick vacuum/boost question (teg racer 877)
bump
Old May 11, 2006 | 11:46 AM
IntegraMastaz's Avatar
my guess is that even if 10-15psi make super power on an engine... I guess its not really that big pression on the vac system wich dont make it blow... the vac feel the pression but for the tubing its not much.
Just my guess..
Old May 11, 2006 | 02:00 PM
Default Re: (IntegraMastaz)
thats pretty much what I thought but what about cars pushin 25+ psi? and my other questions?
Old May 13, 2006 | 08:10 AM
Default Re: (teg racer 877)
I read my vac at the manofold too... good place since its just before air go in the engine.
Dmc1
Jan 26, 2006 11:39 AM
tissimo
Jan 24, 2006 11:49 AM
turbotime
Sep 26, 2005 06:22 AM
B00STED Si
Jan 15, 2005 05:27 PM
b00stedbyFastrax
Apr 15, 2003 05:45 PM
