Moroso GSR Oil Pan
Guest
Posts: n/a
Moroso GSR Oil Pan
Does anyone know if this oil pan will work for a GSR motor? From what I can tell, it SHOULD, but dont know if it really will. I called moroso they said it doesnt, but the guy I talked to didnt know what a gsr was, let alone the difference between the GSR and LS motors.
http://cgi.ebay.com/ebaymotors...ZWDVW
Also has anyone had problems with the newer moroso pans? For this price I figured I might as well get this one, over oem.
i ♥ snails
did you read the bottom??
Fits the following applications:
Honda Acura B16A B16B B17A B18C B18C5 VTEC Type-R Integra
Honda Acura B18A B18B B20B B20Z B-SERIES VTEC Type-R Civic
Honda Engines with B16A (PR3) or B18C (P72) cylinder heads (Integra Type R and Del Sol)
Part # MOR20911
Part # MOR20911
ALl you have to do is go to a website that sells moroso oil pans for hondas and compare the part numbers, if they match.... you get the rest.
I have a new STEEL 5 quart moroso with the kicked out sump and it is official, I prefered the steel anyways because of the sturdyness and stregnth
Re: (95GSRTT)
A catalog I have says.....
1994-1998 Acura Integra 1.8L, VTEC & Non-Vtec; Civic Si 1.6L DOHC B16A3
So I would have to say screw the moroso guy and that they are universal, but if you have a non-vtec you have to buy an extended pickup. Ask the guys in the type-r forum.
Re: (V-SPEC 1)
I'm using the same pan on my built GSR. No problems at all, stock pick-up and gasket are fine.
Got mine from summit racing, for 120....gotta know what you are looking for though, no pic on the site, just a part#
Re: Moroso GSR Oil Pan (White Smoke)
GSR and TypeR oil pan are identical....i am running a Moroso Oil pan...works great...had a Tap in the front for oil return...comes standard with magnetic drain plug...this oil pan gets two from me
Re: Moroso GSR Oil Pan (JDM_Risa)
Mine has the extended sump ( 5qt. ) with the baffles and oil return and extra bung for oil temp, got a STEAL on it for $220 w/ shipping
Re: Moroso GSR Oil Pan (95GSRTT)
http://cgi.ebay.com/ebaymotors...wItem
Show me where, I bought mine not on Ebay and the cheapest I can find is this.....
I have this pan, but haven't put it on yet, seem like a quality piece.
For those of you who are already using it, does the dipstick read full when you fill it? I remember a while back there was a post about this and people were having problems with it. This is also something anyone thinking about getting this pan should probably know.
Re: (1158)
Funny you ask that, I changed my break-in oil the other day and dumped 5qts in it and it was about a quarter inch above the full mark, I didnt pay any attention to it......
Re: (ekhatchgrl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhatchgrl »</TD></TR><TR><TD CLASS="quote">Yes it works, I have one on my gsr motor. </TD></TR></TABLE>
Glad to hear it works.... thats for all the great info
