Kill Switch in an EG w/ a Turbo Timer
Old May 9, 2006 | 11:54 AM
HatchEh2's Avatar
Default Kill Switch in an EG w/ a Turbo Timer
What is needed to put a kill swith in a turbo timed car? obviously the car needs to stay running after i leave it.. so how would a kill switch come to play in this situation?
i was thinking just a starter kill, both a switch and a 'push-hold' button...? how would i go about wiring this up, would i need a relay or could i just throw a switch in the middle of the starter wire? (black/yellow i think it is?)
any help would be appreciated, im just trying to get it done now while my dash and interior is out. Thanks in advance
Modified by HatchEh2 at 11:40 AM 5/10/2006
Old May 10, 2006 | 07:42 AM
HatchEh2's Avatar
Default Re: Kill Switch in an EG w/ a Turbo Timer (HatchEh2)
i know theres gotta be turbo timed guys on here with kill switchs? please, help a brother out living in high risk jersey!!??
Old May 10, 2006 | 07:49 AM
VTteg's Avatar
Find a way to interrupt your starter wires with a switch or two.
Old May 10, 2006 | 07:55 AM
HatchEh2's Avatar
Default Re: Kill Switch in an EG w/ a Turbo Timer (VTteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTteg &raquo;</TD></TR><TR><TD CLASS="quote">Find a way to interrupt your starter wires with a switch or two.</TD></TR></TABLE>
yea i know that, i just dont wanna go snipin wires w/o hearing from someone that did it before. And im wondering, will i need a relay like with fuel cut offs??
Old May 10, 2006 | 09:23 AM
adictionbass's Avatar
i think theres a way you can do it with a relay... i just have no clue how
Old May 10, 2006 | 04:44 PM
HatchEh2's Avatar
Default Re: Kill Switch in an EG w/ a Turbo Timer (adictionbass)
cmon theres gotta be SOMEBODY with a killswitch in there turbo timed car?!?!?!?!
this is holding up me putting my car back together, id rather do it while it just sits as a shell with no motor or interior...
Old May 10, 2006 | 04:53 PM
Dunc's Avatar
BCICAN
PM'ed with a slightly different way...if you are in a high risk area.
Old May 10, 2006 | 05:19 PM
Default Re: Kill Switch in an EG w/ a Turbo Timer (AF-P Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AF-P Dunc &raquo;</TD></TR><TR><TD CLASS="quote">PM'ed with a slightly different way...if you are in a high risk area. </TD></TR></TABLE>
sent you a PM
Old May 10, 2006 | 05:34 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">
sent you a PM</TD></TR></TABLE>
replied
Old May 10, 2006 | 09:49 PM
HatchEh2's Avatar
good ****, but im just lookin to throw a quick, effective kill switch while my cars apart, i didnt wanna just put a switch right smack dab in a circuit w/o relays and such required...
again...ANYONE turbo timed with a kill?? or should i try another form?
Old May 11, 2006 | 05:16 AM
GS-R Civic's Avatar
It can be rigged up with a relay, I had it set up with my old alarm, but got lazy when installing the new one, pm me if you have any questions.
Old May 11, 2006 | 06:18 AM
JK_Motorsports's Avatar
Default Re: Kill Switch in an EG w/ a Turbo Timer (GS-R Civic)
I did it, Press a button once then start the car, car will run after it is turned off, but won't start till the button is pressed. I do a diagram when I have time.
Old May 11, 2006 | 07:07 AM
notoriousB's Avatar
Default Re: Kill Switch in an EG w/ a Turbo Timer (JK_Motorsports)
why not just put a switch in line with the starter "start" signal wire from the ECU? there can't be very much voltage going thru that line.
Old May 11, 2006 | 07:16 AM
Running925's Avatar
Default Re: Kill Switch in an EG w/ a Turbo Timer (notoriousB)
i cut power completely with mine
Old May 11, 2006 | 08:35 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">why not just put a switch in line with the starter "start" signal wire from the ECU? there can't be very much voltage going thru that line.</TD></TR></TABLE>
push start baby...
Old May 13, 2006 | 11:55 PM
HatchEh2's Avatar
isnt the start switch only on autos?
Old Jun 7, 2006 | 04:59 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JK_Motorsports &raquo;</TD></TR><TR><TD CLASS="quote">I did it, Press a button once then start the car, car will run after it is turned off, but won't start till the button is pressed. I do a diagram when I have time.</TD></TR></TABLE>
Did you ever get around to making that diagram?
Old Jun 7, 2006 | 05:49 PM
iBrandon's Avatar
Default Re: Kill Switch in an EG w/ a Turbo Timer (civicdxtyper)
usually the kill switch is wired into the ebrake with a turbo timer....So when you do leave ur turbo timer on...and if sumone just happens to hop in and let the ebrake down...it will shut the car off immediatley....
Old Jun 7, 2006 | 06:02 PM
raceACCORDingly's Avatar
http://www.sonolithics.com/files/bosch.pdf
this pdf shows how you can make stock switches like ebrake, cig lighter, headlight switch, etc... starter/fuel kill switches with a relay
ive thought about a fuel cutoff w/ a turbotimer but its way over my head, starter is alot easier.
imzjustplayin
Apr 17, 2008 09:08 AM
HatchEh2
15
May 18, 2006 09:26 AM
HT Chaplain
Feb 21, 2005 03:55 AM
intekragsr
Jun 11, 2003 08:41 PM
lazyvietboi
Nov 6, 2001 08:58 AM
