block threads stripped...
Old May 10, 2006 | 02:25 PM
EF9ZC's Avatar
Default block threads stripped...
Alright so today i was finally putting on my port flow head and i went to torque the headstuds down. I was doing a 3 stage torque made sense to me 25 50 75. This is a a6 z6. Both head and block recently built. I was turquing 3rd bolt to 75 when bam...stripped. I was hoping it just made a noise like they made noise coming out. But i turned a little more and knew it was stripped so i took it out and all the threads are stuck to the arp bolt. What did i do wrong recently i made thread about torquing and they said most people go to 75 ft lbs. Please info would be nice im ready to just quit
Old May 10, 2006 | 02:35 PM
emotionisdead's Avatar
Very Emergency!!
Default Re: block threads stripped... (EF9ZC)
heli-coil kit. pull the head and by the kit form napa.
Old May 10, 2006 | 02:37 PM
RACEPAK's Avatar
Default Re: block threads stripped... (emotionisdead)
time-sert
Old May 10, 2006 | 02:39 PM
EF9ZC's Avatar
Man but why the hell does that happen. I went to the next one after that and it felt like it was about to strip
Old May 10, 2006 | 03:16 PM
mike93boost's Avatar
heli coil!?!? lol, YOU DO NOT WANT TO USE HELICOILS.
here you go man..
https://honda-tech.com/zerothread?id=1382274
and for sale here..
https://honda-tech.com/zerothread?id=1393720
Old May 12, 2006 | 09:07 AM
EF9ZC's Avatar
Hmm i just want to know this...i drained the coolant but there was still in head and block, like when i took off head coolant was coming out too. So some got in the bolt holes. Would The water get trapped in the bolt holes and not being able to compress any more make the stud come back out with taking the threads with it?
Old May 12, 2006 | 09:20 AM
swatteamtimmah's Avatar
possible but i would think that the coolant is more likely to go up around the threads than just sit there.
Old May 12, 2006 | 10:37 AM
EF9ZC's Avatar
yea thats what i was thinking when i was putting on the head. I couldn't see any other way to do it unless i took block off and dumped it upside down to get coolant out of there.
Old May 12, 2006 | 10:57 AM
splitime's Avatar
Default Re: (EF9ZC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF9ZC &raquo;</TD></TR><TR><TD CLASS="quote">yea thats what i was thinking when i was putting on the head. I couldn't see any other way to do it unless i took block off and dumped it upside down to get coolant out of there. </TD></TR></TABLE>
Roll up pieces of paper towel.
Old May 12, 2006 | 03:06 PM
Tony the Tiger's Avatar
Default Re: (EF9ZC)
Compressed air and a rag..
If the treads are machined really well, then the coolant would be squished and has nowhere to go. It would give a false torque reading. You'd want to clean out all the oil or coolant on all threads before proceeding to the next step.
Old May 12, 2006 | 03:25 PM
i use a wet dry vac..
Old May 12, 2006 | 07:50 PM
nota-eg's Avatar
Default Re: (mike93boost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost &raquo;</TD></TR><TR><TD CLASS="quote">i use a wet dry vac..</TD></TR></TABLE>
Compressed air, rag, and then a shop vac here.
Did you chase the threads before you started putting the studs in?
I torqued mine to 72ft/lbs (all my TQ wrench would go to) and I was uneasy about putting them on that tight. I tried checking the ARP website awhile back, but it was down for maintenance (2nd hand studs, unused, but unpackaged), so I had to go off of hearsay.
Old May 12, 2006 | 08:16 PM
boostismycrack's Avatar
E-thug
Default Re: (nota-eg)
definately time sert it. happened to mine also. rs machines chaeged me$40 a hole.
Old May 13, 2006 | 05:56 AM
EF9ZC's Avatar
Well if anyone is intrested block is for sale cp pistons 9:1 pauter rods benson sleeves acl bearings so on and so on cost me 3400 or so
Old May 13, 2006 | 02:08 PM
how much?
why dont you just keep it and buy my d16 head bolt hole kit? ill sell it CHEAP compared to what i paid for it.
Old May 13, 2006 | 04:56 PM
EF9ZC's Avatar
probably like 1500 never seen boost and only 1500 miles thats over half the price i say its a steal
Old May 17, 2006 | 02:39 PM
Anthony's Avatar
Mr. Fuch-yu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93boost &raquo;</TD></TR><TR><TD CLASS="quote">how much?
why dont you just keep it and buy my d16 head bolt hole kit? ill sell it CHEAP compared to what i paid for it.</TD></TR></TABLE>Listen to the man. Helicoils are prone to pulling out again because they aren't as strong as the original threads. Time-sert is the way to go. Dont scrap a project b/c of a tiny little setback. Keep on trucking. And, Mike is an honest seller. He'll do you a good deal. Check his vouch thread in his sig.
-Anthony
Old May 17, 2006 | 02:41 PM
EF9ZC's Avatar
Naw just dont got any more money to throw into this project or energy, others can benefit from it i dont care ne more
Old May 17, 2006 | 04:41 PM
earl's Avatar
Default Re: (EF9ZC)
Actually helicoils are used in everyday aircraft construction. Every threaded piece of aluminum has a helicoil. They work better than most people give them credit for. We made close to 700 with a block with 5 head bolt helicoils and no head gasket problems to date.
Old May 17, 2006 | 05:13 PM
Group Tenacity's Avatar
Default Re: (earl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RACEPAK &raquo;</TD></TR><TR><TD CLASS="quote">time-sert </TD></TR></TABLE>
We use time-serts and have never had a problem with them...
willard steen
Apr 5, 2016 12:22 AM
bigpudge813
Jun 22, 2013 10:12 AM
EJ1_Can2
Sep 10, 2010 08:18 AM
spooledex
Nov 5, 2006 08:22 PM
sonofsam
Nov 7, 2005 08:26 AM
