Precision SC50 .48 a/r turbo on a GSR...powerband?
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
I'm switching over most of my SOHC turbo kit over to a GSR motor eventually, and I'm wondering what the powerband would be like on this setup, with a stock GSR motor.
The setup is:
- Revhard tubular manifold, ceramic coated
- Precision SC50 .48 a/r turbo (basically a T3/T04e 50-trim, with a .48 a/r exhaust wheel and ported housing)
- 3" downpipe, cat, & KTeller exhaust
- 2.5" cold-side, 2" hot-side IC piping
- Greddy Type-S BOV
- DRAG III FMIC
- Crome Pro & RC 550's
Any tips on how to get the most out of this setup? I am wondering, will this turbo make power to the GSR's redline, even with the .48 a/r exhaust housing?
I know a lot of people are going to say "go with the .63 a/r exhaust housing for a GSR motor", but I like the quick spool of this turbo, and I want to see how far I can take it.
Anyone who's actually RUNNING a T3/T04e 50-trim or Precision SC50 .48 a/r, post up your experiences with it
The setup is:
- Greddy Type-S BOV
- DRAG III FMIC
Re: Precision SC50 .48 a/r turbo on a GSR...powerband? (boostincoupe)
Either way it will be slow, Fnan
How high are you planning to rev this best? Do you have a compressor map for it?
It's been "rated" to about 400-450 hp (maybe that was the .63 ar). I think you'll be just fine for street driving. Your 3" DP and exhaust will help free things up.
Re: Precision SC50 .48 a/r turbo on a GSR...powerband? (Snafubmx234)
Bump, because I'm considering running this turbo on my next setup, but probably with a .63 a/r
I have the same turbo with .48a/r on my D16 and rev to 8000rpm. Turbo doesn't seem to choke at all.
Re: Precision SC50 .48 a/r turbo on a GSR...powerband? (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 »</TD></TR><TR><TD CLASS="quote">I have the same turbo with .48a/r on my D16 and rev to 8000rpm. Turbo doesn't seem to choke at all. </TD></TR></TABLE>
Good to hear.
Any B-series guys running this turbo?
Good to hear.
Re: Precision SC50 .48 a/r turbo on a GSR...powerband? (DRAGLS)
Alot of people seem to think the .48A/R will die off really bad at high rpm, but it really doesn't.
Sorry, mine is not .48ar.
Here is my Lsvtec 81.5 mm.
Precition sc50 ball bearing with .63ar hot
purple - 7 psi
green 11 psi
red - 14 psi
purple - 7 psi
green 11 psi
red - 14 psi
bump cause i'd like to know.
im running the t3/t4oE 50trim w/ .48a/r housing on my ls turbo right now and i like it alot... But im going ls/vtec this summer so i need to know if i should keep it to reach 350-400whp.
for answers
for answers
Any GSR guys running this turbo?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">Any GSR guys running this turbo?</TD></TR></TABLE>
I don't run a GSR (as you know), but I'm sure it'll spool fast and have great midrange power. A .63 would be better for top-end power but IMO the .48 will be just fine.
Re: Precision SC50 .48 a/r turbo on a GSR...powerband? (dornon13)
The .63 will support more topend power but spool slower. You'll be fine with a stock gsr and the .48ar. It will prolly lightup the tires like crazy - you'll love it.
liam
liam
I have a built/sleeved 1.9l b18c5 w/ .48 exhaust side t3/t4 and at 19 psi it pulled 331whp on a mustang dyno @8000rpm (closer to 400 on dynojet). full boost before 4k and YES it does light up the tires like no other. Hope this helps.
JoePSI
10-25-2007 12:03 PM
dester223
11-01-2004 07:37 PM
