need help no boost
Old May 9, 2006 | 07:01 AM
turbodegsi's Avatar
Default need help no boost
ok guys i need help. i had a ssautocrap manifold. boosted fine for the time it lasted.
the last time i saw boost it was in 4 gear and it made it to 10 pounds, then it just quit. found manifold cracked again. so now i have a revhard manifold and can't get it to boost for ****. tried a new wastegate and still nothing. checked over all ic pipings and vaccum lines still nothing.... the only thing i can think of is the waste gate vaccum that is on the compressor housing isn't pushing enough for it to open the wastegate. could i try a straight source of vaccum??? thanks ahead of time
Old May 9, 2006 | 09:42 AM
turbodegsi's Avatar
Default Re: need help no boost (turbodegsi)
anyone???
Old May 9, 2006 | 10:36 AM
em1 Ziggy's Avatar
yes im getting no boost same problem as you...
Old May 9, 2006 | 01:50 PM
turbodegsi's Avatar
afternoon bump
Old May 9, 2006 | 01:58 PM
RogueWorks's Avatar
if it's not opening the wastegate, you would be overboosting
Old May 9, 2006 | 09:38 PM
turbodegsi's Avatar
evening bump really need help. nothing seems to work
Old May 10, 2006 | 07:57 AM
turbodegsi's Avatar
morning bump
Old May 10, 2006 | 08:26 AM
yee SERIOUS's Avatar
try another vac source. what kind of turbo are you running?
Old May 10, 2006 | 06:16 PM
turbodegsi's Avatar
already tried a diffrent source of vac. still nothing. but i think i found the problem. i think the turbo charger took a **** on me. when you feel for shaft play it's not bad, but when i turn the car on and watch it spin it doesn't spin till you rev it and when you watch the turbo spin while giving it gas, then once in a while you can see the shaft just wobble. i think it's losing pressure due to shaft play leaking a little bit of oil too. good luck to the rest of you who have no boost problems. i hope a new turbo takes care of it.
Old May 11, 2006 | 08:49 AM
yeah, go ahead and replace the turbo. my first turbo stopped spinning after a month. it was my daily driver back then, so i just drove with it on. a week later, i lubed the fins on the compressor side with some oil. started it up and it actually started to spin.
when i was replacing the turbo...i found this:
better take yours apart and check it!
BeArDy
Welding / Fabrication
Aug 26, 2011 01:52 PM
rick_rabies
Oct 28, 2009 08:30 AM
1fastlude1
May 2, 2008 01:40 PM
turboH22Aakkord
Oct 11, 2005 07:52 AM
Accel Junky
Jan 25, 2004 07:50 PM
