Greddy Blue Box HELP!!
Old May 10, 2006 | 09:22 PM
TKteg's Avatar
Default Greddy Blue Box HELP!!
I just purchased a greddy turbo kit for 96-99 GSRs. I have an 00 GSR and i know this means i will need to cross reference the ECU pin out and the wiring instructions from greddy to wire the bluebox. I looked at this:
Greddy Blue box
Blue ----------------> TAP TO #1 INJECTOR A4
Orange--------------> TAP TO #2 INJECTOR A3
Yellow----------------> TAP TO #3 INJECTOR A2
Purple----------------> TAP TO #4 INJECTOR A1
Brown----------------> TAP TO RPM SIGNAL A20
Gray------------------> TAP TO INJECTOR GROUND A9
Black------------------> TAP TO ECU GROUND A 10
Red--------------------> TAP TO ECU POWER A 11
Green-----------------> CUT WIRE D3 HOOK TO ECU SIDE
White------------------> CONNECT CUT WIRE D3 TO ENGINE BAY
and this: http://technet.ff-squad.com/wiring.obd2b.htm
from the pin out i cant find any of these
RPM SIGNAL A20
Am I missing them in the diagram or what? Someone help!
Old May 10, 2006 | 10:13 PM
TKteg's Avatar
Default Re: Greddy Blue Box HELP!! (TKteg)
HELP!!
Old May 11, 2006 | 02:08 AM
kcjohnnyboy's Avatar
i say ditch the blue box and search for another fuel management...
chipped ecu is wat im going for and i have the same setup as yours that i will be puttin on this summer (greddy kit)...i had the emanage that came with the kit and i just sold that and going another route
Old May 11, 2006 | 05:38 AM
EE_Chris's Avatar
Default Re: Greddy Blue Box HELP!! (kcjohnnyboy)
<U>OBD2a = OBD2b</U>
A20 = B13
A9 = B20
A10 = B2
A11 = B1
D3 = C17
Old May 11, 2006 | 07:58 AM
TKteg's Avatar
Default Re: Greddy Blue Box HELP!! (EE_Chris)
okay thanks alot man!
Old May 16, 2006 | 11:10 AM
TKteg's Avatar
when wiring the blue box wires to the ECU pins do I have to solder the wires to the pins??
Old May 16, 2006 | 11:29 AM
RACEPAK's Avatar
you dont have to.... but its more reliable...
Old May 16, 2006 | 11:41 AM
EE_Chris's Avatar
Like he said, you don't have to. But if you don't and you throw a CEL or something goes wrong, don't overlook it as a possible culprit.
Old May 16, 2006 | 01:28 PM
TKteg's Avatar
ok thanks guys..iam thinking of just maybe wrapping the wire around the pin and taping it..i dunno something not as permanant as soldering..
Old May 17, 2006 | 03:17 AM
EE_Chris's Avatar
to that idea.
Old May 20, 2006 | 05:02 PM
TKteg's Avatar
haha i decided to solder them everythings good now thanks!
Old May 21, 2006 | 08:24 PM
Truv603's Avatar
Hey TKteg...does the turbo work yet or are you still on jack stands?
Old May 21, 2006 | 09:29 PM
TKteg's Avatar
Default Re: (Truv603)
yeah man it is iam running like 20 psi..so u finally signed up for honda-tech huh
Old May 23, 2006 | 05:56 PM
Truv603's Avatar
thats right...i did...now how's about some pictures of the ride...i heard you runin like 45 psi tho...haha
Old May 23, 2006 | 06:40 PM
EX-T's Avatar
Default Re: (TKteg)
I sure hope you're kidding about the 20 psi with the blue box!
Old May 24, 2006 | 05:50 AM
TKteg's Avatar
Default Re: (EX-T)
haha yeah man iam kidding
Old May 24, 2006 | 09:57 AM
Truv603's Avatar
haha...^^EX-T...no i just started really using my acct and me and tkteg have an inside joke haha
xiLLtegRax
Dec 26, 2007 07:06 PM
ITR97-143
Mar 13, 2005 12:17 PM
heygotboost
Mar 2, 2005 10:41 AM
DeadLock23
Oct 29, 2003 05:15 AM
VerbalKint
Dec 8, 2002 09:58 PM
