Nitrous h22
Old May 9, 2006 | 02:46 AM
mozzandherb's Avatar
Honda-Tech Titanium Member
Default Nitrous h22
I'm lazy so I haven't searched, I just got off of work. Anyway I bought a used jdm h22a and it's in my 92 Accord. Is it safe to run a 50 shot of nitrous on stock internals? What should I do before I install a kit? Thanks.
Old May 9, 2006 | 04:51 AM
The Weather Man's Avatar
What should u do before you install a kit? - answer: research
Do NOT do a fogger system - do a direct port system. And get hondata or something so you can control the timing better.
Old May 9, 2006 | 07:01 AM
631 Teggy's Avatar
Default Re: (The Weather Man)
50-65 shot will be fine. My friend has been spraying a 55 dry shot for like 2 years on his stock duceduce - no problems. Direct port is pointless for a 55 shot. His car made 233whp with a 55 shot and mild cams.
Get colder spark plugs, get a fuel pump (not necissary but its insurance) and make sure your tune is safe.
55 shot is not much so don't frett.
Old May 9, 2006 | 03:38 PM
Default Re: (631 Teggy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 631 Teggy &raquo;</TD></TR><TR><TD CLASS="quote">50-65 shot will be fine. My friend has been spraying a 55 dry shot for like 2 years on his stock duceduce - no problems. Direct port is pointless for a 55 shot. His car made 233whp with a 55 shot and mild cams.
55 shot is not much so don't frett.</TD></TR></TABLE>
You obviously don't know ****.
How can u say a fuel pump and spark plugs are insurance - but suggest him to use a fogger system? A direct port system would be insurance.
How about this, both of u need to do research.
Old May 9, 2006 | 05:02 PM
631 Teggy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Weather Man &raquo;</TD></TR><TR><TD CLASS="quote">
How about this, both of u need to do research. </TD></TR></TABLE>
Experience &gt; Research. Keep reading magazines, and jumping on h-t direct-port bandwagons. There is NO NEED for DP when you are only spraying a 55 shot. kthx
Old May 9, 2006 | 05:32 PM
sc4dr's Avatar
Damn man, relax. I spray a 75 wet shot, and I know a lot of others running the same setup. If done properly there is NO problem whatsoever. No need to get ignorant.
Old May 15, 2006 | 10:39 AM
Ray-mond's Avatar
No a Direct port would not be insurance for a 50 shot ur fine with a fogger system a dry kit will still give u some fuel.A 55 shot DP sux its a little harder to tune with a DP on a 50 shot u just get fogger kit and plugs and retard ur timing 2 degrees and have fun. O and to explain my self on the DP sucking with a 50 shot.With a 50 shot u get to much fuel that will puddle up in the manifold.DP is good for 100+ I know this becuase I had a 50 shot DP on my old LS man that thing would just bogg.But would take a 100 shot like a champ.
Old May 15, 2006 | 11:14 AM
allmotorh22's Avatar
Default Re: Nitrous h22 (mozzandherb)
I sprayed 125 on my h22 for 2 years with no problems.
Old May 15, 2006 | 12:56 PM
Default Re: (sc4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc4dr &raquo;</TD></TR><TR><TD CLASS="quote">
Damn man, relax. I spray a 75 wet shot, and I know a lot of others running the same setup. If done properly there is NO problem whatsoever. No need to get ignorant. </TD></TR></TABLE>
Who ever said there was a problem????
Did I........i don't think so...........
I just offered my opinion - "Don't do a fogger system"
I said a direct port would be "insurance." Meaning that it would be much more safe to do a direct port than just a wet shot.
And absolutely no one here can argue with me about that. Thats just a simple fact.
Just because you made 2+ years doing a wet shot doesn't mean anything. We're just talkign about "insurance"
Forgive me for wanting to do things the safe way. I would rather not take a chance with my engine.
Rather do it right the first time.
Old May 15, 2006 | 04:05 PM
sc4dr's Avatar
So I guess your way is the "right" way. Every setup is different, and if your only spraying a 75 shot or lower, you can't go wrong with a fogger system. And btw, this is what most people run anyway.
Old May 15, 2006 | 09:54 PM
Ray-mond's Avatar
Rather do it right the first time. </TD></TR></TABLE>
I hope ur saying this from experience and not just from half the junk u read on here and Import tuner that stuff will roat ur brain.
And no one said anything was wrong with a DP but DP is not right for every setup.I don't know but 2+ years on the Bottle is pretty good if u ask me.And if u don't want to take a (CHANCE) with ur motor don't hook the bottle up.Or even race it if that.Just drive like little Ms.Daisy every where u go.
Old May 18, 2006 | 04:16 PM
Default Re: (Ray-mond)
You should really do a direct port kit you never can go wrong with that.
Old May 18, 2006 | 04:24 PM
Boner_Ben's Avatar
Direct port for a 55 shot is completely pointless. I'd either run a bigger shot and go with a direct port, or just use a single fogger. As was said before, experience &gt; research.
Old May 23, 2006 | 02:36 PM
Default Re: (Boner_Ben)
yeah true I was thinking bigger than that like 125 or 150
Old May 23, 2006 | 03:44 PM
3a_eg_hatch's Avatar
Default Re: (allmotorh22)
im selling my nx wet kit for 400
Roca fella Bryan
Jan 19, 2008 07:23 AM
projectef
15
Jun 3, 2007 07:54 AM
stockcolt
Dec 14, 2005 12:51 PM
Ddogz15
Apr 25, 2004 11:47 AM
integranator
Dec 22, 2002 02:58 PM
