Help with injector size
Old May 13, 2006 | 06:39 AM
alexb16hb's Avatar
Default Help with injector size
Hello. I am wondering if I can safely run saturated RC 550 cc injectors in my turbocharged b16. I will be having it tuned with Neptune and I am hoping to hit 300 whp. It seems that a lot of people are using 750's but I am wondering if that is for later mods or if they are actually needed.
Thanks
What are the RC 550's good up to.
Old May 13, 2006 | 07:26 AM
97turboteg's Avatar
Default Re: Help with injector size (alexb16hb)
i know DSM 450's can handle around 300whp range, you can probably get 350-379whp out of 550's. ppl just go bigger so they dont have to upgrade in the feature.
Old May 13, 2006 | 07:33 AM
EpicTuning's Avatar
RC 550 will be fine for your set up. Its just nice to buy injectors once thats why people go over kill on the size. Its nice not to use 100% of the duty cycle.
Old May 13, 2006 | 08:10 AM
alexb16hb's Avatar
Default Re: Help with injector size (EpicTuning)
any one running the 550's in the 300 whp range that care to share what their duty cycle was at.
Thanks
Old May 13, 2006 | 09:45 AM
alexb16hb's Avatar
i found this on Evans-tuning. Does this seem accurate.
310cc 200~220whp
370cc 220~280whp
440cc 280~330whp
550cc 330whp~380whp
660cc 380whp~425whp
720cc 425whp~475whp
880cc 475whp~525whp
980cc 525whp~600whp
If so I should be great using 550's.
Old May 13, 2006 | 09:47 AM
2k.civic.si's Avatar
the rc saturated 750cc injectors are only a few bucks more then the 550's...i have never had a problem idling 750's on motors even as small as 1.6liter....these injectors also give you much headroom
Old May 13, 2006 | 10:14 AM
cuin9sec
Guest
Posts: n/a
if you already have the 550's then keep them. if you havent purchased a set yet then i would definately go with the 750's.
Old May 13, 2006 | 10:18 AM
hondaguyef's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alexb16hb &raquo;</TD></TR><TR><TD CLASS="quote">
550cc 330whp~380whp
Yep, and that's underestimated IMO^^. If you're only "hoping" to hit 300whp than the 550's wil be just fine. Although, as stated above I've never had a problem idling 750's (I.E. Passed inspection w/ 750rpm Idle w/ flying colors) and they are only a few dollars more. Good luck.
Phil
DC2fab
Apr 9, 2010 09:31 PM
Luke G.
Jan 23, 2010 11:53 AM
Change
Sep 25, 2004 08:24 PM
boostedlude3g
Jun 25, 2003 08:22 AM
Crisgo
Apr 9, 2003 04:32 PM
