turbo vacuum lines?
Old May 8, 2006 | 06:54 PM
xcellorator's Avatar
Default turbo vacuum lines?
im confused with where my vacuum lines for my turbo should be running. so far i have the BOV should go to a T, one end going to the manual boost controller the other going to the intake manifold. then the other end of the MBC goes to the wastegate. do i need any other vacuum lines? does this routing seem ok?
Old May 8, 2006 | 07:05 PM
B18 CYA's Avatar
wastegate can run off the turbo, or if your turbo has no tee for it just run it off of vacuum from ur intake manifold
19_HaTcH_92
Feb 20, 2010 03:24 PM
almostjdmeg
Mar 10, 2008 01:00 PM
leinadmiih00
Jan 20, 2007 04:58 PM
STL01Civic
May 8, 2005 02:39 PM
B18 CYA
Aug 5, 2004 10:01 PM
