38mm wastegate good for 600whp
Since my car is down for a rebuild. I was wondering if i should change my tial 38mm with 1 bar. Should i go 44mm or stay with 38mm. I ran 22psi minimum before on my stock engine. So my pump gas will be 22psi and race gas 40psi.. Im wondering if the 38mm will hurt or not
Re: 38mm wastegate good for 600whp (Quickgti1.8t)
Low boost.. Big turbo = Big wastegate
High Boost.. Big Turbo = Small wastegate
Reason for... If you run low boost with a big turbo, wastegate works harder.. So it needs to be bigger to prevent creep.
Going to a 44mm wouldnt hurt.
Re: 38mm wastegate good for 600whp (CRVRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRVRX »</TD></TR><TR><TD CLASS="quote">A well placed 38mm Tial will hold a GT35R down to 7 psi no problem. An Inline Pro manifold for instance.</TD></TR></TABLE>
i wont handle running 7psi. My minimum will be 20psi daily
go with the 44mm a GT35R will not flow that much boost it will die out well before 40psi.
Instead of worrying about how much boost you are going to running. You should look at it if you can make 400 on 10lbs of boost or 400 on 21lbs of boost which would be safer and allow the engine to last longer
Re: 38mm wastegate good for 600whp (Fitti (Godzilla))
well its a VW 1.8T its pretty different then a honda. I basically need twice the PSI you guys run to get the same power
Markb16a
10-16-2007 08:45 PM
