B18C1 EK Coupe 1/4 mile
Head:
OBD2 gsr head
Minor port/polish
ITR intake cam/ GSR Exhaust cam
Block:
JE pistons(9:1)
Eagle H beam rods
JDM ITR tranny w/ factory LSD
ACT xtreme pp
Kinetic Motorsport Turbo manifold
GT2540r turbo(I think)
3" downpipe
3" cat back exhaust
Tial 40mm wg
Tial BOV
OBD1 conversion
AEM EMS
14psi super rich street tune
MSD 6al
MSD Blaster SS
MSD dizzy
MSD wires
ngk 7's gapped to .025
made 259whp at 14psi
ran 13.110 @ 110.5mph. on street tires with interior in. Ill post more info and pictures later.
OBD2 gsr head
Minor port/polish
Block:
JE pistons(9:1)
Eagle H beam rods
ACT xtreme pp
3" downpipe
3" cat back exhaust
Tial 40mm wg
Tial BOV
OBD1 conversion
AEM EMS
MSD 6al
MSD Blaster SS
MSD dizzy
MSD wires
Re: B18C1 EK Coupe 1/4 mile (beerbongskickass)
yeah I totally forgot to drop my tire pressure down, it was at 40psi all day
I woulda probably ran more than the 5 times that I did but i have a tps problem that all of the sudden started after racing.
Re: B18C1 EK Coupe 1/4 mile (Cpt Ben)
Dropping the tire pressure on your street tires (if that's what your running) won't help that much. You will need some drag radials or better yet slicks.
Sounds like you have a lot left in your motor though, seeing that it's built and all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass »</TD></TR><TR><TD CLASS="quote">Work on your traction. You have traps for low 12's.</TD></TR></TABLE>
Yes, what were the 60's? Definately looks like there's alot more in the setup.
Re: B18C1 EK Coupe 1/4 mile (drintegra)
Yeah, why such a lower Hp number? At 14psi, and build bottom, you should be in the mid-300's, but I guess you will up the power later.
Re: B18C1 EK Coupe 1/4 mile (Mugencrxsir1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 »</TD></TR><TR><TD CLASS="quote">Yeah, why such a lower Hp number? At 14psi, and build bottom, you should be in the mid-300's, but I guess you will up the power later.</TD></TR></TABLE>
It's dependant upon the size of the turbo. He doesn't have an enormous turbo.
Re: B18C1 EK Coupe 1/4 mile (RyanCivic2000)
I still would of been expecting the HP to be around 300hp at that psi, and I would definately be disappointed if I had a gsr with rods, pistons, at 14psi putting out HP below 300 I mean you can't tell me that 259whp sounds low for 14psi gsr, and even with a smaller turbo, maybe 8psi.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 »</TD></TR><TR><TD CLASS="quote">I still would of been expecting the HP to be around 300hp at that psi, and I would definately be disappointed if I had a gsr with rods, pistons, at 14psi putting out HP below 300 I mean you can't tell me that 259whp sounds low for 14psi gsr, and even with a smaller turbo, maybe 8psi.</TD></TR></TABLE>
I think you're to fixed on psi and forgetting that it's all about CFM.
r/t .159
60' 2.276
1/8 8.684
MPH 85.55
1000 11.067
1/4 13.110
MPH 110.15
I dont understand the tune myself, aparently its just rediculously conservative/safe. How can I tell the difference between the garrett GT series turbo's all I know about the one I have is that the compressor side is .70ar. I didnt build the car so im not sure about that part.
This was my second time ever on the drag strip(4th race ever) so im sure ill be able to better those times a bit as I get more experienced. I plan on having the car retuned for 16-18psi this summer once im working full time and then ill see what my hp is at.
60' 2.276
1/8 8.684
MPH 85.55
1000 11.067
1/4 13.110
MPH 110.15
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cpt Ben »</TD></TR><TR><TD CLASS="quote">
ran 13.110 @ 110.5mph. on street tires with interior in. Ill post more info and pictures later.</TD></TR></TABLE>
Wow, that must have been a conservative tune!
Good traps dude, gut it (pull the seats), get some 22x8 slicks, and put down some mid 12's.
Re: B18C1 EK Coupe 1/4 mile (HamiltonRex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">Wow, that must have been a conservative tune!
Good traps dude, gut it (pull the seats), get some 22x8 slicks, and put down some mid 12's.</TD></TR></TABLE>
Only problem, I have huge front rotors(AEM) which I need a 16" wheel to clear. So either I go back to stock brakes or do some fender mods to run a 16" wheel w/ a slick
