ls t super afc settings
Old May 10, 2006 | 02:40 PM
skunkedteg108's Avatar
Default ls t super afc settings
I have a turbo ls and im wondering wut good settings would be for the apexi super afc running about 7 lbs on the stock motor and injectors, if anyone has settings on their afc that work pretty well and get as much pull as possible i could use sum help....thanks
Old May 10, 2006 | 02:41 PM
Mag00n's Avatar
Default Re: ls t super afc settings (skunkedteg108)
crome pro and more boost
Old May 10, 2006 | 04:05 PM
Blaze45's Avatar
Brrraaaap!
Unless your going to run higher fuel pressure the stock injectors wont be able to keep up and then if you do that, your fuel pump wont be able to keep up. Get some DSM 450s and a 190lph or better fuel pump, hook up a wideband 02, retard the timing a few degrees and have it tuned. You definetly should get bigger inejctors. People have pushed 7psi with a rising rate regulator and even more boost then that buy why risk it? If at all possible, get CROME or uberdata and have it tuned.
Blaze
jpickett23
Feb 28, 2012 02:59 AM
turboant
Nov 22, 2003 03:15 AM
suprajb
Nov 17, 2002 11:00 AM
89dxhunchback
Jul 14, 2002 09:55 AM
Chip398193
Nov 19, 2001 10:55 AM
