Wich bearings?
Old May 8, 2006 | 02:59 PM
dohdoh420's Avatar
Default Wich bearings?
I was just wondering what would be the best bearing for my boosted d16y8? I plan to run 15 to 22 psi.. would OEM bearings hold up to that? are the ones on ebay any good? thanks
Old May 8, 2006 | 03:24 PM
Mugencrxsir1's Avatar
Default Re: Wich bearings? (dohdoh420)
acl
Old May 8, 2006 | 04:09 PM
y7turbo's Avatar
Default Re: Wich bearings? (Mugencrxsir1)
oem are best. you can get away with using acl's if you measure and the oil clearance is ok for it.. if not then use oems.
Old May 8, 2006 | 04:50 PM
USDM 4G VTEC's Avatar
OEM all the way and the ONLY way
other companies only sell STD and oversize bearings, and they never give you the right clearances
Old May 8, 2006 | 06:11 PM
stealthmode62's Avatar
Default Re: (USDM 4G VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDM 4G VTEC &raquo;</TD></TR><TR><TD CLASS="quote">
other companies only sell STD and oversize bearings, and they never give you the right clearances</TD></TR></TABLE>
Piston manufacturers only sell std or oversized pistons. It's your machine shop that gives them the right clearances, not the pistons. It's the same with bearings.
If I had to give advice on which bearings to use, I'd say the right sized ones.
Old May 8, 2006 | 08:59 PM
dohdoh420's Avatar
Default Re:
ugh... damn.. I just dont want to spin any.. I hear OEM's are only good to 400 degrees, and the ones on ebay are good to like 1400.. I dont want to make the wrong decision
Old May 9, 2006 | 09:39 AM
dohdoh420's Avatar
Default Re: Re: (dohdoh420)
anyone else have any suggestions?
I've also read things about what color the bearings are rated at? what color would be the best? where can I see this color chart? are teflon coated bearings worth the extra money?
Old May 9, 2006 | 10:47 AM
cuin9sec
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 &raquo;</TD></TR><TR><TD CLASS="quote">acl </TD></TR></TABLE>
Old May 9, 2006 | 12:56 PM
White Smoke's Avatar
i my honda
Global Mod
OEM
The ONLY way to do it right
Mhollaek9
Sep 1, 2007 03:06 PM
vtec-gorilla
Aug 14, 2006 10:45 PM
RTW DC2R
Jul 9, 2006 08:30 AM
BLK99VTECR
16
Jul 21, 2005 08:01 PM
GSRCRXsi
14
Jul 11, 2005 07:09 PM
