Engine Blowing Code: High Circuit Input IAT
Old May 13, 2006 | 09:11 AM
96 GSR-T's Avatar
Default Engine Blowing Code: High Circuit Input IAT
What would be the causes of a high input to the idle air tempurature sensor on my GSR? Is it going bad or an wiring issue.... believe the code is a P0113
Old May 13, 2006 | 11:13 AM
JSPECSIR's Avatar
Default Re: Engine Blowing Code: High Circuit Input IAT (96 GSR-T)
you will need to find out from a service manual what resistance it should be and check it with an ohm meter to see if it is in spec. all it is is a resistor that changes resistance with temperature change.
Old May 13, 2006 | 11:33 AM
96 GSR-T's Avatar
Default Re: Engine Blowing Code: High Circuit Input IAT (5THGENSI)
I looked at its temperature reading on my OBD2 scanner and on a 70 deg. day like today it was reading -40 degrees....... Even if I find out the spec for it, is it adjustable?
Old May 13, 2006 | 12:11 PM
nonvtecD's Avatar
Just sounds like it's going bad, try a known good one from a friend and see what happens.
Old May 13, 2006 | 01:09 PM
96 GSR-T's Avatar
Default Re: (nonvtecD)
I was told I can take one off any OBD2 honda and it will be compatible..... CRV, Accord, Civic etc.... is this correct?
Old May 13, 2006 | 01:38 PM
nonvtecD's Avatar
I don't see why not, as long as you're still using an obd2 computer.
Old May 15, 2006 | 03:07 PM
JSPECSIR's Avatar
as long as the resistance range is the same it will work
dinamozagreb
Jun 27, 2017 07:21 AM
mrem1dipppn
Feb 2, 2012 09:02 AM
Ready4lyf
Apr 22, 2011 06:53 PM
black_99SI
Dec 7, 2007 05:14 AM
dakuda
Jan 22, 2007 01:36 PM
