Do I really need a block guard???
Old May 11, 2006 | 10:55 PM
Urugly's Avatar
Default Do I really need a block guard???
Ok guys...I am finally getting my first turbo project on its way:
I got a DRAG kit from a buddy of mine cheap that I am going to slap on a B16A2 motor.
The head is going to have:
P/P 3 angle valve job.
Dual valve springs/retainers
Skunk 2 cam gears
Blox Turbo Cams
Blox intake manifold
Edelbrock 65mm throttle body
Bottom:
Eagle rods
Arias pistons 10:1 compression
Type R oil pump
Type r water pump
JDM type r crank pulley
Tranny:
S80 JDM with LSD
Competition clutch stage 2
Competitoni fly wheel 12 lbs
All run with Hondata s200 w/boost.
I am planning on running between 300-375 HP at most pushing 12-14 lbs.
DO I NEED A BLOCK GUARD SINCE IT IS OPEN ANYWAYS JUST IN CASE??? WOULD IT HURT??
WHAT BRANDS DO PEOPLE TRUST AND WHERE DO YOU BUY IT??
Thanks.
Old May 11, 2006 | 11:08 PM
SynTeg's Avatar
Don't waste your money on a blockguard. Instead put it towards a good tune.
Old May 12, 2006 | 07:14 AM
Urugly's Avatar
any other suggestions?? So a block guard isn't always necessary......
as long as I get a good tune...
Old May 12, 2006 | 08:13 AM
beerbongskickass's Avatar
Default Re: (SynTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SynTeg &raquo;</TD></TR><TR><TD CLASS="quote">Don't waste your money on a blockguard. Instead put it towards a good tune.</TD></TR></TABLE>
Old May 12, 2006 | 08:22 AM
komat's Avatar
Default Re: (beerbongskickass)
its going to take more thne 12-14lb to make it to 375
Stationwagon
Jun 7, 2013 02:25 PM
1.6eR_sleepeR
Jan 28, 2008 05:50 PM
MustWonder
Oct 9, 2005 02:12 AM
highrevnef
May 17, 2005 11:15 AM
swlabhot
Jan 16, 2003 03:08 PM
