GSR TURBO PROBLEM!!!!
Old Sep 7, 2007 | 11:00 PM
Chee_dog's Avatar
Default GSR TURBO PROBLEM!!!!
I have a eg with gsr tubo in it, last night i did a few pulls and the car just doesn't feel right and yes its tuned at 13psi, I down to 3rd gear all the way to redline and then shift to fourth and thats where the problem begin. The rpm keeps reving at 7,8 to 8K at redline and you can feel the car shake, is this a sigh of bad clutch? Could it be that i have a catback on? Could it be wastegate not holding boost, any help i would perfer appriciate.
Old Sep 8, 2007 | 12:29 AM
Schister66's Avatar
Man U FTW
give us more details about the setup.....from what you have, i couldnt even give you an educated guess
Old Sep 8, 2007 | 01:38 PM
Chee_dog's Avatar
Default Re: (Schister66)
Well, my car has a built block with 9:1 pistons and 3 bar map/exedy clutch 3 puck and more.. But yea last night my car was acting wierd. As said in first post i down to 3rd gear and when i shifted to 4th the car just REVS as like iam in neutural. I tried checking for leaks and havent seen none yet. I am sure i did shift nearly at 7.6k LMK what you guys think may be wrong, Thanks. If you guys need more on the mod list and ill take a time and put it down.
Old Sep 8, 2007 | 01:48 PM
Hondaruss's Avatar
Default Re: GSR TURBO PROBLEM!!!! (Chee_dog)
When you shift are you doing WO throttle shifts or are you lifting? have you had this happen in any other gear?
Old Sep 8, 2007 | 01:52 PM
CoreyR's Avatar
Default Re: GSR TURBO PROBLEM!!!! (Hondaruss)
if it revs like your in neutral the only thing that could even cause that is a slipping clutch.
Old Sep 8, 2007 | 01:59 PM
integraRS-T's Avatar
sounds like the clutch is taking a **** on u
Old Sep 8, 2007 | 05:04 PM
Chee_dog's Avatar
Default Re: (integraRS-T)
This means a new clutch? I didnt get a chance to ask the previous owner when did he install the clutch. Also it seems to slip on high RPMS on any gear but street drivings are fine....
RevYouUp
May 25, 2014 05:09 PM
ChillOutWayne
Jul 31, 2004 10:35 PM
tac379
17
Aug 18, 2003 06:17 PM
wutangben
May 21, 2003 05:26 PM
djtony5
Jan 5, 2003 06:43 PM
