2.5-3 BAR map sensor.
Old Sep 12, 2007 | 11:54 PM
DrivinVtec's Avatar
Default 2.5-3 BAR map sensor.
where an what do I need to make this work on my p28 w/crome (h22a4) is it just plug it in an im good or do i need program the ecu to reconise the new map?
Old Sep 12, 2007 | 11:57 PM
DrivinVtec's Avatar
is this what i need?
http://cgi.ebay.com/ebaymotors...60522
simple install?
Old Sep 13, 2007 | 01:38 AM
cbustuner's Avatar
The xenocron one will work.You need to redo your map in crome for the whatever new map sensor you are going to use
Old Sep 13, 2007 | 10:23 AM
DrivinVtec's Avatar
Default Re: (cbustuner)
is it hard to wire this pig in?
Old Sep 13, 2007 | 02:12 PM
mtber's Avatar
Default Re: (DrivinVtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DrivinVtec &raquo;</TD></TR><TR><TD CLASS="quote">is it hard to wire this pig in?</TD></TR></TABLE>
No it is easy...
Old Sep 13, 2007 | 06:41 PM
SOHC_MShue's Avatar
Default Re: 2.5-3 BAR map sensor. (DrivinVtec)
its very easy just follow the diagram mtber posted and you will definately need to get the voltage to pressure scale in you crome file changed to run the new sensor.
Old Sep 13, 2007 | 06:47 PM
DrivinVtec's Avatar
thanks
beak
Jul 9, 2006 01:28 PM
hxtasy
Mar 17, 2006 06:16 PM
Dr Pooface
Nov 19, 2005 12:37 PM
Sketch_hs
Jun 22, 2004 08:12 AM
CaptainMorgan
Jan 27, 2004 04:45 PM
