2 step help??
Old Sep 9, 2007 | 05:58 PM
boostedb20z's Avatar
Default 2 step help??
ok i tuned my car today for 11psi on crome 11.5s in boost all good and i was looking thought crome plugins and i see they have 2 step and i set it up in crome under options but it doesnt work what do i have to do ???
and it also has a cel shift light and i set it up and it works but y doesnt my 2 step.
Old Sep 9, 2007 | 06:13 PM
SovXietday's Avatar
Default Re: 2 step help?? (boostedb20z)
Crome doesn't have a working 2step.
Old Sep 9, 2007 | 06:14 PM
Schister66's Avatar
Man U FTW
Default Re: 2 step help?? (SovXietday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">Crome doesn't have a working 2step.</TD></TR></TABLE>
i wonder how my Crome chipped P28 runs my 2 step then......must be magic
Old Sep 9, 2007 | 06:19 PM
SovXietday's Avatar
Default Re: 2 step help?? (Schister66)
Do you have FTL or 2step, because it's not the same thing.
Old Sep 9, 2007 | 06:30 PM
i want 2 step how did u make yours work???
Old Sep 9, 2007 | 06:38 PM
JaredKaragen's Avatar
Default Re: (boostedb20z)
make sure the VTEC speed check is on,
set the RPM for 2step in the launch control, then set the timing as low as possible in that R range on the lowcam, then put the fuel pig *** rich on the fuel area where it's gonna be; and that's a pseudo 2-step. Just make sure it kicks into VTEC or you will have one weird *** pull.
Old Sep 9, 2007 | 06:42 PM
THEDirtyDseriesWOOT's Avatar
i made 9 psi on my d16 with a 57trim on crome launch control... hondata is alot better i can make about 15psi off the line with my gt30R on my d16
dmullinax96
11
Feb 17, 2012 03:33 PM
tealsvteceg
Apr 22, 2008 08:01 PM
CeeJayy
12
Feb 15, 2008 11:50 PM
dominate9
Oct 20, 2003 09:07 PM
