Drag Radial for 16' wheel?
Old Sep 13, 2007 | 09:06 AM
vtec.dc2's Avatar
Default Drag Radial for 16' wheel?
Are there any options in drag radials for 16" wheel? is there something that will fit without spacers etc..
Old Sep 13, 2007 | 12:33 PM
SovXietday's Avatar
Default Re: Drag Radial for 16' wheel? (vtec.dc2)
There are, but nothing that will fit on a Honda.
You're going to need a 14-15" rim.
<-- has 16" too.
Old Sep 13, 2007 | 02:23 PM
vti2's Avatar
I think yokohama advan 048 will fit, but they are very expensive
Old Sep 13, 2007 | 03:58 PM
rmcdaniels's Avatar
Hoosier 225/50 R16 Drag Radials fit great. It's an excellent drag radial too, much better than the BFG or Nitto DR's. I got the same 60' times with my Hoosier DR's that I did with my 24.5x8 slicks.
Old Sep 13, 2007 | 04:51 PM
sc4dr's Avatar
Default Re: Drag Radial for 16' wheel? (rmcdaniels)
60' times???
Old Sep 13, 2007 | 05:21 PM
rmcdaniels's Avatar
Default Re: Drag Radial for 16' wheel? (sc4dr)
1.8's in a full-weight EM1 -w- a 265 lb driver, same as I used to get -w- my Hoosier 24.5x8's on 13" Lensos, but a lot more stable at over 100 MPH.
Old Sep 13, 2007 | 05:41 PM
sc4dr's Avatar
Very nice I heard that you can't buy that tire anymore.
Old Sep 13, 2007 | 05:46 PM
rmcdaniels's Avatar
It's still listed on the Hoosier site. Most dealers, like Tire Rack, don't carry it though. If you call one of the distribution centers listed on the Web site, then they should be able to hook you up.
Old Sep 13, 2007 | 06:19 PM
sc4dr's Avatar
I was running the m&h dot bias ply, but the 26" diam. was a little taller than I wanted. I was going through the traps at around 7,500 rpm in 4th, and would lose too much boost in between shifts.
Do you know off hand if they offer a 15" tire?
Sorry to threadjack
Old Sep 13, 2007 | 06:55 PM
rmcdaniels's Avatar
They have a 225/50 R15 at 24.2"
https://www.hoosiertire.com/specdrag.htm#DOT
Old Sep 13, 2007 | 07:04 PM
sc4dr's Avatar
Thanks man, always a pleasure
Old Sep 13, 2007 | 07:08 PM
.RTErnie's Avatar
rmcdaniels,
In your opinion...best DR for a 14" wheel? Looking for a fair-weather traction solution.
Old Sep 13, 2007 | 07:14 PM
blackeg's Avatar
Default Re: Drag Radial for 16' wheel? (SovXietday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SovXietday &raquo;</TD></TR><TR><TD CLASS="quote">There are, but nothing that will fit on a Honda.
&lt;-- has 16" too. </TD></TR></TABLE>
im in the same boat. im currently trying to trade my 16s for 15s so i can buy some bfg radials again
Old Sep 13, 2007 | 07:15 PM
sc4dr's Avatar
Default Re: Drag Radial for 16' wheel? (.RTErnie)
Daily driven?
Old Sep 13, 2007 | 07:18 PM
.RTErnie's Avatar
400 ft lbs of torque and Daily Driven.
Old Sep 13, 2007 | 07:46 PM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">Hoosier 225/50 R16 Drag Radials fit great. It's an excellent drag radial too, much better than the BFG or Nitto DR's. I got the same 60' times with my Hoosier DR's that I did with my 24.5x8 slicks.</TD></TR></TABLE>
they looks like they will fit but will they pass for everyday driving like bf goodrich drag radials?
Old Sep 13, 2007 | 07:49 PM
rmcdaniels's Avatar
Hoosiers are not for a DD, they got no treads, just a wee line around the middle. Stickiest daily drivable DR I've run has been a BFG DR, although I think MT makes a streetable drag tire that's better.
You could also go with an r-compound road-race tire like a Toyo RA1, I run those on my hatch and they are decent for a DD if you don't shave them, very soft compound and you won't get in trouble if you get caught out in the rain.
Also ask in the drag forum, they would know better there, I haven't been to the drag strip in forever.
Old Sep 13, 2007 | 07:55 PM
rmcdaniels's Avatar
Damn Neon torque monster, you going to be running it anywhere the 23rd-29th, I'll come and see since I'll be stuck in Portland that week.
Old Sep 13, 2007 | 08:30 PM
vtec.dc2's Avatar
will R comound work as good as say bf goodrich drag radial?
Old Sep 13, 2007 | 08:40 PM
rmcdaniels's Avatar
It'll work better for most things, although it's not as soft as a BFG and has much stiffer sidewalls, so probably not for drag launches.
Old Sep 13, 2007 | 08:57 PM
vtec.dc2's Avatar
hmm.. i see bf goodrich makes 255-50-15.. that would proabbaly never work.. right? and be tall as ****..
i undestand about sidewall, but what about compound, is it just as sticky.. if thats the case i can live with poor launch
Old Sep 13, 2007 | 09:09 PM
rmcdaniels's Avatar
I think they make 225/50-15's, at least Tire Rack shows them.
BFG DR compound is treadwear 00, Toyo RA1 treadwear is 40.
Old Sep 13, 2007 | 10:06 PM
So Cal So Boosted's Avatar
whats better for drag racing and daily driving.
The MT drag radial.....or the BFG drag radial??? I am torn between these two choices right now.
Old Sep 14, 2007 | 04:03 AM
sc4dr's Avatar
Default Re: Drag Radial for 16' wheel? (So Cal So Boosted)
The MT is a 26" tire, which will give great traction on the street, but a little tall for under 500 hp at the track. The bfg dr is just under 24" and works very well at the track, but still spins quite a bit on the street. I just took off a set of 225/50/15 bfg's because there bald after 300 miles, and they only hook up in fifth gear which I don't use (on the street)
M&H dot is also a great street/race tire for high horsepower/high torque cars. I can get some traction in third with this tire. It's a bias ply and it's big and bad.
Old Sep 14, 2007 | 05:50 AM
vtec.dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">I think they make 225/50-15's, at least Tire Rack shows them.
BFG DR compound is treadwear 00, Toyo RA1 treadwear is 40.</TD></TR></TABLE>
yeah they do make 225-50-15.. i meant to say they make 255-50-16, since we're talking 16's... but i guess that would never fit and be way too tall..
