b16a turbo choice
Old Sep 9, 2007 | 10:04 PM
EGLUVN's Avatar
Default b16a turbo choice
ok so heres the deal. i have a jdm b16a and im to the point where im ready for boost. i want a tthat will boost 18 psi. ive heard that with the b16a i need to smaller turbo due to the lack of displacement. maybe a .54 cold and a .48 hot? or am i way off. i want it to be at peak boost by around 5 grand (8 psi) and i would like to hear of any places with some cheap but decent turbo parts. i.e. wastegate interdcooler etc. and would u recommend running an internal or external wastegate.
Old Sep 9, 2007 | 10:14 PM
RCautoworks's Avatar
Default Re: b16a turbo choice (EGLUVN)
I would suggest a 50, or a 57 trim turbo, we sell parts, check our signature
Old Sep 9, 2007 | 10:22 PM
EGLUVN's Avatar
Default Re: b16a turbo choice (RCautoworks)
thanks for the site. is 2.5 inch big enough for 8 psi. or does the amount of boost not matter. and should i use an internal or external wastegate. wastegate size?
Old Sep 9, 2007 | 10:27 PM
Its not about being to big, 2.5 will work but the question should be. How much power are you going to make, and will 2.5 really effect that goal you want to reach. You have to realize how much power you want to make, and then see how much boost you want to run then. If you don't want to boost a lot but want to get the most out of the setup, 3 inch should be used.
Old Sep 10, 2007 | 12:53 AM
ralph11sec's Avatar
how much is you budget for the turbo parts?
Old Sep 10, 2007 | 05:25 PM
EGLUVN's Avatar
Default Re: b16a turbo choice (ralph11sec)
not cheap but now expensive. 2500 hopefully. hopefully to get 300 wheel. i know thats high for a stock motor but its high goal
Old Sep 10, 2007 | 05:30 PM
We can set you up with a semi complete ( all you would need is small stuff ) turbo kit for 1,700. Inclues major components such as garrett turbo, tial wastegates, greddy bov, intercooler and oil line kits. IM me if your interested.
Old Sep 11, 2007 | 04:05 PM
EGLUVN's Avatar
pmed
Old Sep 11, 2007 | 04:13 PM
JSPECSIR's Avatar
ive got a b16a. i use a master power t3/t4, .50 a/r comp. .63 exh. 57 trim. stage 3 wheel. i usually get full boost between 4500-5000. hope that helps.
Old Sep 11, 2007 | 06:43 PM
turbohf's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGLUVN &raquo;</TD></TR><TR><TD CLASS="quote">ok so heres the deal. i have a jdm b16a and im to the point where im ready for boost. i want a tthat will boost 18 psi. ive heard that with the b16a i need to smaller turbo due to the lack of displacement. maybe a .54 cold and a .48 hot? or am i way off. i want it to be at peak boost by around 5 grand (8 psi) and i would like to hear of any places with some cheap but decent turbo parts. i.e. wastegate interdcooler etc. and would u recommend running an internal or external wastegate.</TD></TR></TABLE>
why 18psi? 18psi is different for every turbo... i boost 18psi and make 392whp... an 18g for example, isnt gonna do that at 18psi...
B16s dont "NEED" small turbos... click my sig but i dont get any boost till 5500rpms...
b16a4
Nov 13, 2007 08:08 AM
CBEengineering
Nov 1, 2006 08:45 PM
DxTrix
Sep 9, 2006 03:50 PM
93hatched_projekt
Nov 23, 2005 12:31 AM
B6tPoweredMx3
Jun 19, 2005 06:41 AM
