Could it be done??
Old Sep 6, 2007 | 04:17 PM
drewbie's Avatar
Default Could it be done??
I was thinking,
I have never heard of anybody building an 8 valve motor. (yeah prolly because it is a stupid motor to build)
but I was thinking, could you build a sohc 8 valve 400whp motor?
on 93 octane?
Old Sep 6, 2007 | 04:34 PM
tokesGTR's Avatar
Default Re: Could it be done?? (drewbie)
Sure you can. When it's a 2.3L ford stroked out to almost 3 litres on a tall deck block, with the head hogged to all ******* hell and back, and running a giant turbo.
I honestly don't think anyone has cracked 400 WHP on straight up 93 octane with a 16-valve SOHC honda, leaves me nothing to believe you could do it with less head flow.
Old Sep 6, 2007 | 07:31 PM
boostedcivicsir's Avatar
Mr. Badwrench
i would think it can be done.
are you talking in terms of say a cx motor?
on pump i dont know. it comes down to how good the engine works and moves air.
Old Sep 6, 2007 | 08:50 PM
drewbie's Avatar
Default Re: Could it be done?? (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">i would think it can be done.
on pump i dont know. it comes down to how good the engine works and moves air.</TD></TR></TABLE>
yeah CX.
i have a CX head laying around im gonna analyze the thing and see how much it could be ported.
i bet if the combustion chamber could be re worked a bit and a few millimeters ( )added to the valves the head wouldnt be that bad with some porting.
fully built d series block would be needed though.
Old Sep 6, 2007 | 11:36 PM
tokesGTR's Avatar
And even with a few mm larger valves you still aren't touching the capabilities of a 16v head. A good comparison, IMHO, is modular ford engines. A 4.6 with 2V heads will max out at about 600-625 RWHP on pump gas. A 4.6 with 4V heads is 900+ RWHP capable on pump gas. Pretty massive difference.
And especially with this setup, why even bother handicapping yourself to an 8V sohc? Just run a 16v head, it's not like they're expensive.
Old Sep 6, 2007 | 11:48 PM
tony413's Avatar
S-10 SOHC
patriot performance stage 2 head
crane custom grind cams
and way to many other mods hit around 300hp crank but only 230Whp
side note the S-10 2.2L block is basically a 2.2L cavi motor
Old Sep 6, 2007 | 11:53 PM
tokesGTR's Avatar
Default Re: (tony413)
Bull-*******-**** on a head that barely hits 200 CFM's of air on the intake making 230 RWHP on a naturally aspirated 4-cylinder. Did you forget to mention the 75 HP shot of nitrous? Way to pull that one out of your ***.
You sound dumber and dumber every time you post. Are you going to tell us now you custom engineered a SOHC 8 valve head for your make believe EVO8/9 you said you owned, pulled the turbo off and made 250 AWHP?
Old Sep 7, 2007 | 12:01 AM
tony413's Avatar
Default Re: (tokesGTR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tokesGTR &raquo;</TD></TR><TR><TD CLASS="quote">Bull-*******-**** on a head that barely hits 200 CFM's of air on the intake making 230 RWHP on a naturally aspirated 4-cylinder. Did you forget to mention the 75 HP shot of nitrous? Way to pull that one out of your ***.
You sound dumber and dumber every time you post. Are you going to tell us now you custom engineered a SOHC 8 valve head for your make believe EVO8/9 you said you owned, pulled the turbo off and made 250 AWHP?</TD></TR></TABLE>
it wasnt N/A it on a T28
and what are you talking about didnt i school your dumb *** pretty good a while back about cams. also go take a look at patriot performance
Old Sep 7, 2007 | 12:13 AM
tokesGTR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony413 &raquo;</TD></TR><TR><TD CLASS="quote">
and what are you talking about didnt i school your dumb *** pretty good a while back about cams. also go take a look at patriot performance </TD></TR></TABLE>
School my *** pretty good on what? You said 404's were bigger than CTR cams, you were wrong and off by a ton.
And I looked at patriot performance, and their 2.2 head flows, like I said, a whopping 200 CFM's on the intake. Takes a lot of boost to make 400 WHP out of a small motor with a head flowing 200 CFM's
And what the expletive does a 2.2L truck motor making 230 WHP have to do with trying to hit almost double that on a smaller motor with an even smaller head? Keep your "technical" bullshit to hondahookup from now on, maybe they'll believe the cars you pretend to have.
dsmIA
12
Jul 26, 2005 12:37 PM
93FastLs
Dec 3, 2004 11:54 AM
bartek_b
Nov 17, 2003 06:54 PM
egturbo
Oct 5, 2003 09:42 PM
B_CRUZ!
Jul 30, 2003 08:11 AM
