Question for AEM Tuners - Im trying to convert v1.03 to v1.11
2001 Acura Integra Turbocharged with aem 30-1010 box currently running v1.03
I used the conversion notes and followed all the instructions and converted to v1.11 but when I select the new v1.11 file to open it I see a whole bunch of things that are not set. What is this about and have anybody else experience this.
It looks like this
and when I scroll down, these are all that is listed. Aem pros, please take the time to read through it and any insight on my tune or anything would be much appreciated. I know AEM has way more features than I would never use but is this just a list of the options that Im not using and I can still use this file? or are these critical things that need to be addressed?
Table 'Step #2 Target' converted to 'Motor #1 Target'
Table 'Step #2 Base' converted to 'Motor #2 Target'
Table 'VVC Error' converted to 'VVC#2 Error'
Table 'VVC Duty' converted to 'VVC#1 Error'
Option TPER has not been set
Option Alt Spark Fixed has not been set
Option User #1 Period M has not been set
Option Ign Fixed has not been set
Option NOS Control has not been set
Option Crank Sync Skip has not been set
Option Nissan has not been set
Option No Forced Sync Test has not been set
Option Ign Mux Ign#1 has not been set
Option NOS Overrev On has not been set
Option A/C On Delay has not been set
Option Frequency #4 Div has not been set
Option Ign Retard C has not been set
Option Ign Retard M has not been set
Option 2Step Retard C has not been set
Option 2Step Retard M has not been set
Option Fuel Cut Load has not been set
Option Ign Cut C has not been set
Option Ign Cut M has not been set
Option 2Step Ign Cut C has not been set
Option 2Step Ign Cut M has not been set
Option Fuel Cut C has not been set
Option Fuel Cut M has not been set
Option 2Step Fuel Cut C has not been set
Option 2Step Fuel Cut M has not been set
Option Fuel Pump Prime has not been set
Option Alt Off Over RPM has not been set
Option NOS Overrev Off has not been set
Option NOS Switch In has not been set
Option NOS Output has not been set
Option Out NOS has not been set
Option NOS Reinstate Load has not been set
Option Staged Flow 2 exp has not been set
Option Ignition Fixed has not been set
Option Alt Ignition Fixed has not been set
Option Idle 1/2 Stepper has not been set
Option Idle 3/4 Stepper has not been set
Option Idle 5/6 Stepper/DC has not been set
Option Idle 7/8 Stepper/DC has not been set
Option Motor #1 FB Input has not been set
Option Motor #1 Clock has not been set
Option Motor #2 Clock has not been set
Option Motor Fail Detect has not been set
Option Motor #2 Swap Motor has not been set
Option Motor DC Pair has not been set
Option Motor DC has not been set
Option Motor #1 Power Save has not been set
Option Motor #2 Power Save has not been set
Option Motor #1 Default has not been set
Option Motor #1 Dead Band has not been set
Option Fuel Off Coolant Mi has not been set
Option Motor #2 FB Input has not been set
Option Motor #1 Analog Inp has not been set
Option Motor #2 Default has not been set
Option TP Raw Invert has not been set
Option AFR Switch Invert has not been set
Option Motor #2 Dead Band has not been set
Option Motor #2 Analog Inp has not been set
Option Motor Update Rate has not been set
Option PWM#9 Invert has not been set
Option PWM#10 Invert has not been set
Option Cam#1 Start has not been set
Option Cam#2 Start has not been set
Option VVC#1 FB P has not been set
Option VVC#1 FB I has not been set
Option VVC#2 FB P has not been set
Option VVC#2 FB I has not been set
Option VVC#1 stopped has not been set
Option VVC#1 default has not been set
Option VVC#1 invert has not been set
Option VVC#2 invert has not been set
Option TP1 Frequency Out has not been set
Option Frequency Spd has not been set
Option Frequency M has not been set
Option VVC#2 stopped has not been set
Option VVC#2 default has not been set
Option Retard Limit Rev has not been set
Option 2Step Retard Rev has not been set
Option MAF Scalar has not been set
Option MAF Offset has not been set
Option Out Act T PWM#1 has not been set
Option Out Act T PWM#2 has not been set
Table VVC#1 Duty has not been set
Table VVC#2 Duty has not been set
Map NOS Fuel has not been set
Map NOS Ignition has not been set
Map Valve#1 has not been set
Map Valve#2 has not been set
It looks like this
