Main Studs Necessary?
Old Sep 12, 2007 | 11:54 AM
lsturbo*'s Avatar
Default Main Studs Necessary?
I am building a B18B turbo with hopes to hit 375 - 400 HP. Motor was completely ripped down and sleeved, with all new internals except crank and cams. I will obvisously use head studs in the reassembly, but do you think main studs are necessary? I am not looking to save money, but I would think that changing to studs would require a line hone which I would like to avoid if possible. I am looking for a strong motor but don't want to go over the top.
Old Sep 12, 2007 | 12:30 PM
adseguy's Avatar
Default Re: Main Studs Necessary? (lsturbo*)
No, not necessary for that power. just make sure they are really clean and you get good lube. The key to all of this is consistency. The more consistent the torque number the less warpage there will be and the less wear and tear in the end.
Old Sep 12, 2007 | 03:12 PM
rmcdaniels's Avatar
I would do it anyway. The main caps on my B16 were moving a little around 400 WHP with the stock bolts, although the car ran fine for over a year. When I had it redone I got it line honed by RLZ for the ARP main studs and it's still running the last I heard (sold the motor to somebody when I was done with it). Just be careful who you get to do the mains, the machine that's used for a steel block can ruin a Honda block.
Old Sep 12, 2007 | 03:19 PM
SPOOLINmatt's Avatar
Default Re: Main Studs Necessary? (rmcdaniels)
600 on a previous motor with stock bolts, NO PROBLEMS THERE.
Old Sep 13, 2007 | 02:30 PM
lsturbo*'s Avatar
Yeah, I am leaning toward stock bolts that way I don't have to line hone. I don't want to introduce any unnecessary problems if I can avoid them. This is similar to my decision of not using a main girdle because my power requirement are simply not that high. Thanks for the input, It's hard to decide what is necessary when this is my first build.
gooblinn258
Apr 21, 2014 05:21 AM
Cap'N Chronic
Oct 16, 2011 06:47 AM
wildoutwhitegsr
18
Feb 17, 2006 07:09 AM
KooK
Jan 26, 2006 08:58 AM
DamonBoost
Jun 18, 2002 05:24 PM
