Motorola map sensor
Old Sep 9, 2007 | 06:39 AM
crawlin's Avatar
Default Motorola map sensor
I need to upgrade my stock map sensor. i was looking at the 3 bar motorola map sensor on ebay and such. i was wandering how many people are using them and if you guys have any type of problems with them. i need to order one tonight so any input would be helpful.
thanks
Old Sep 9, 2007 | 12:46 PM
HiProfile's Avatar
Default Re: Motorola map sensor (crawlin)
As long as you get your EMS calibrated properly for them (pgmfi.org will have the numbers/calcs for them), they work great. They are very linear, and very cheap. The down side is they don't use a standard connector, at least not standard for automotive use.
Old Sep 9, 2007 | 02:16 PM
Topdawgg's Avatar
ive had mine for 2 seasons and its never given me a problem...
I run a GM 3 Bar now.. also with no problems
Old Sep 9, 2007 | 04:17 PM
xenocron's Avatar
Default Re: Motorola map sensor (Topdawgg)
Motorola Map sensors FTMFW...I've been running my 4 bar for almost a year...2.5 bar for 2 years before that.
Old Sep 9, 2007 | 06:07 PM
akira712's Avatar
Default Re: Motorola map sensor (xenocron)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">Motorola Map sensors FTMFW...</TD></TR></TABLE>
x2
Old Sep 9, 2007 | 07:00 PM
CivicVX94's Avatar
does anyone sell these with the correct plugs to use as a direct replacement? or do you have to do the wiring yourself?
Old Sep 9, 2007 | 07:36 PM
crawlin's Avatar
Default Re: Motorola map sensor (CivicVX94)
you have to do the wiring yourself but it comes with instructions. its 3 wires how badly could it go wrong.
Old Sep 9, 2007 | 07:52 PM
mtber's Avatar
The 2.5 bar sensor does a great job & is very reliable.
Old Sep 10, 2007 | 04:44 AM
USDM 4G VTEC's Avatar
Default Re: Motorola map sensor (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">The 2.5 bar sensor does a great job & is very reliable.
wow, i made that picture long time ago... im glad it has become quite popular! lol
Old Sep 10, 2007 | 05:33 AM
crawlin's Avatar
Default Re: Motorola map sensor (USDM 4G VTEC)
so you have to pin the wires into the sensor?
Old Sep 10, 2007 | 05:48 AM
HiProfile's Avatar
Yes, and that picture is the 2.5 bar sensor. The 3 bar only comes in the micro size IIRC, with a 1/8" port and TINY legs - you have to solder them onto it, as its meant to be put on a PC board. I'm surprized Xenocron didn't pimp his adapter boards for them yet
CivicVX94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crawlin &raquo;</TD></TR><TR><TD CLASS="quote">you have to do the wiring yourself but it comes with instructions. its 3 wires how badly could it go wrong.</TD></TR></TABLE>
if you have to pin the wires into the sensor i'd rather pay any extra $20 for a plug and play sensor. i suck at wiring and would rather pay more than do shotty/questionable work, expecially with a map sensor...
Old Sep 10, 2007 | 05:58 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicVX94 &raquo;</TD></TR><TR><TD CLASS="quote">
if you have to pin the wires into the sensor i'd rather pay any extra $20 for a plug and play sensor. i suck at wiring and would rather pay more than do shotty/questionable work, expecially with a map sensor...</TD></TR></TABLE>
then instead of you doing it..
a- either get the pigtail for the motorola (just go to digikey and ask the online support)
b- get someone who can do it for you
Old Sep 10, 2007 | 06:13 AM
crawlin's Avatar
well i got the 3 bar map sensor so i guess ill have to sodder the wires on it shouldnt be to bad. will see when it gets here in the mail in a few days
Old Sep 10, 2007 | 08:18 PM
xenocron's Avatar
Default Re: Motorola map sensor (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">Yes, and that picture is the 2.5 bar sensor. The 3 bar only comes in the micro size IIRC, with a 1/8" port and TINY legs - you have to solder them onto it, as its meant to be put on a PC board. I'm surprized Xenocron didn't pimp his adapter boards for them yet </TD></TR></TABLE>
The 2.5 Sensor kit is the easiest really...just three easy wires to splice in.
I have the 3 and 4 bar kits in either DIY or already soldered up with the board Dave Blundell & I designed together.
I only suggest the mini 3 bar and 4 bar kits if you really need to run that much boost and possible want to HIDE this tiny map sensor inside your stock MAP for a stealth look.
Old Sep 10, 2007 | 09:31 PM
CivicVX94's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xenocron &raquo;</TD></TR><TR><TD CLASS="quote">I have the 3 and 4 bar kits in either DIY or already soldered up with the board Dave Blundell & I designed together. </TD></TR></TABLE>
thank god Dave is my tuner, now i don't have to worry about it
Old Sep 12, 2007 | 02:01 PM
crawlin's Avatar
edit
Modified by crawlin at 4:03 PM 9/12/2007
phan222001
Aug 17, 2007 05:07 AM
Greg H
Sep 23, 2006 06:58 AM
turbolshatch
Feb 2, 2006 06:06 AM
null.
Dec 15, 2005 06:35 PM
CiViC SiR
Jul 27, 2003 06:57 PM
