Going to dyno tune saturday, need last adjustments!
so im finally getting my del sol turbo dyno tuned!!
i got everything i need and i think im ready but i got one problem. I connected my manual turboxs boost controller and i cant raise boost?
I got the 6psi spring and using a tial 38mm wastegate. Below is a diagram of how i have my vacc lines hooked up
I will unscrew the small bolt inside the boost controller and boost wont go up it will stay at 6psi Any advise why or what im doing wrong? Im hoping to get this problem solved before i go tuning.
Also im open to tips for tuning, anything i should get or bring let me know
Thanks
Thanks
Re: Going to dyno tune saturday, need last adjustments! (turbosol18)
Edit:
How many turns have you given it before trying to raise the boost? Typically it will take about 2-3 turns on the SBC before you'll start increasing your boost.
Re: Going to dyno tune saturday, need last adjustments! (PrecisionH23a)
i thought i could either get source from the turbo itsself or the Intake manifold?
Well anyways where do i have to hook up the vacuum source?
i tried turning it and turing it and doesnt raise boost stays the same...just to make sure im doing it right, to raise boost you untighten the screw right?
At least thats what the boost controller its self says
anyone know the correct way to connect it? I thought i had it right but boost wont go up?? anyways ive searched but cant find any pics or diagrams
The nipple pointing down on the BC should go to the side port of the WG. The side nipple on the BC should go to the compressor housing.
Yours is backwards... just switch the lines on the BC.
Man U FTW
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">The nipple pointing down on the BC should go to the side port of the WG. The side nipple on the BC should go to the compressor housing.
Yours is backwards... just switch the lines on the BC.</TD></TR></TABLE>
There should be a description on the MBC itself...i believe my Hallman had one anyway
Re: Going to dyno tune saturday, need last adjustments! (Schister66)
you got it man...i had the vacuum lines connected wrong...
finally got to raise the boost boost controllers FTW
Synapse
10-05-2007 01:12 PM
