having a problem making boost
Old Sep 13, 2007 | 04:54 PM
fasterthenU's Avatar
Default having a problem making boost
this is a standard set up, ramhorn, t3tsomthing turbo, 63. ex housing blah blah
the wastgate is a 46mm turbo smart with 10 pound spring it was blowing the wastegate right after vtec all the way till redline and only making around 7.5-8psi, using a boost controller I could not get the car past 10 psi, put a stiffer spring, and still only about 11 psi, can not find a boost leak anywhere, except for when it opens the wastegate durning a pull.
any ideas?
Old Sep 14, 2007 | 12:06 AM
Tony the Tiger's Avatar
Default Re: having a problem making boost (fasterthenU)
Where was your boost signal source?
Try relocating it and getting the boost signal from the intake manifold and see if it makes a difference.
061000rr
Jun 14, 2011 04:37 AM
ivt-t
Apr 21, 2007 06:13 PM
cajnatc
Jun 13, 2003 07:43 AM
FUP23
Sep 30, 2002 09:15 PM
