Plug gap question...??
Old Sep 12, 2007 | 05:04 AM
DeDonDeRosa's Avatar
Default Plug gap question...??
OK buddy of mines got a gsr with jrsc @ 6psi and he put in bkr7e-11's and left the stock gap at .044 is that too big. i hear people runnin like .028 to .034 he has no probs at all car drives fine no det and smooth to redline. please let me know
no probs with the .044 gap but i wanted to see if there were any adavantages/disadvantages let me know thank you very much
Old Sep 12, 2007 | 06:58 AM
Dunc's Avatar
BCICAN
Default Re: Plug gap question...?? (DeDonDeRosa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DeDonDeRosa &raquo;</TD></TR><TR><TD CLASS="quote">OK buddy of mines got a gsr with jrsc @ 6psi and he put in bkr7e-11's and left the stock gap at .044 is that too big. i hear people runnin like .028 to .034 he has no probs at all car drives fine no det and smooth to redline. please let me know
no probs with the .044 gap but i wanted to see if there were any adavantages/disadvantages let me know thank you very much</TD></TR></TABLE>
He could also get the NGK BKR7E instead. Those have a smaller gap from the factory (I believe it is .038) and are used when reducing the gap to ~.028. The -11's are good for that because when you bend the grounding strap, it is at a pretty good angle comparitively.
If he is using them at .044 and has no problems, then there is no need to mess with them.
Old Sep 12, 2007 | 07:03 AM
Schister66's Avatar
Man U FTW
The reason people close the gap on their plugs is to prevent spark blow-out. If your buddy is not having any problems at .44, then leave it alone. If he ever develops ignition problems, drop to a set of BKR7e plugs because they have a smaller gap (as Dunc mentioned). If those become a problem, you can further gap them. Right now i run a .30 gap on BKR7E plugs (315whp @ 10psi)
Old Sep 12, 2007 | 07:48 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 &raquo;</TD></TR><TR><TD CLASS="quote">The reason people close the gap on their plugs is to prevent spark blow-out. If your buddy is not having any problems at .44, then leave it alone. If he ever develops ignition problems, drop to a set of BKR7e plugs because they have a smaller gap (as Dunc mentioned). If those become a problem, you can further gap them. Right now i run a .30 gap on BKR7E plugs (315whp @ 10psi)</TD></TR></TABLE>
yup. im .018 - .020 700whp 34psi.
Old Sep 12, 2007 | 08:48 AM
Default Re: (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">
yup. im .018 - .020 700whp 34psi.</TD></TR></TABLE>
I thing your running a dat more boost lol
Old Sep 12, 2007 | 08:50 AM
Default Re: (DeDonDeRosa)
thanks guys
DeDonDeRosa
Nov 12, 2006 10:42 AM
DeDonDeRosa
Nov 7, 2006 12:19 PM
DeDonDeRosa
Mar 8, 2006 04:04 PM
wtc7676
Apr 2, 2004 10:55 AM
preludesh012001
Sep 23, 2003 05:47 PM
