turbo feed line size?
Old Sep 10, 2007 | 10:50 PM
DrivinVtec's Avatar
Default turbo feed line size?
-3AN or -4 AN??
t3/t4 turbonetics 60 trim .63 ar
Old Sep 11, 2007 | 01:58 AM
mighty137's Avatar
Old Sep 11, 2007 | 04:19 AM
mike93eh2's Avatar
-3 with restrictor
Old Sep 11, 2007 | 08:05 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (mike93eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh2 &raquo;</TD></TR><TR><TD CLASS="quote">-3 with restrictor </TD></TR></TABLE>
although i have been told that is not needed, iti s good insurance.
the old rule was -4 with and -3 w/o
Old Sep 11, 2007 | 09:03 AM
mike93eh2's Avatar
Default Re: (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">
the old rule was -4 with and -3 w/o</TD></TR></TABLE>
depends on the turbo really..
if it has a restrictor than why the need for a bigger line ??
Old Sep 11, 2007 | 09:08 AM
Mr. Badwrench
its for the older kits that only came with the -4 line.
my drag kit from '01 never had a restrictor, and never passed oil with a -3 line. f-r said i dont need a restrictor with my current setup. but have had oil passing issues. but from what i have heard it is the t3t67 normality.
was always told -3 line w/o is fine.
and if you are running -4 line you need a restrictor.
now on a huge t4 frame i would think different.
Old Sep 11, 2007 | 09:09 AM
turbodano's Avatar
You need to check the oil pressure at the turbo and then decide what you need to do from there. If you see over 55 psi at idle (hot) I would use a restrictor but if it is lower and you have a good drain no restrictor is needed. You can use -3 or -4 there is not much difference between the 2 line sizes. -3 is the smaller of the 2 and will restrict some of the oil flow to the turbo.
Old Sep 11, 2007 | 09:15 AM
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">its for the older kits that only came with the -4 line.
now on a huge t4 frame i would think different.</TD></TR></TABLE>
oh i thought you meant that if you have a restrictor you need to run -4..
i would use a restrictor if i was you.
Old Sep 11, 2007 | 09:38 AM
turbodano's Avatar
i would use a restrictor if i was you.</TD></TR></TABLE>
Check the oil pressure at the turbo first before you put the restrictor in first. You have to know what you are dealing with first. If you have low oil pressure at the turbo and you don't check it before you install the restrictor you could cause a turbo failure.
Old Sep 11, 2007 | 09:48 AM
DrivinVtec's Avatar
i dont even think i have a restrictor. but no passing oil right now. ill prolly get a -3 an be good with it.
Thanks fellas.
Old Sep 11, 2007 | 12:07 PM
Topdawgg's Avatar
i have -4 with a restrictor on my 35R
shao_6780
May 25, 2008 07:55 AM
seeeya04
Dec 12, 2005 05:08 PM
the.hamburglar
Aug 2, 2005 01:07 PM
boost fed ls
Aug 1, 2003 12:20 AM
PM-Performance
Nov 12, 2002 12:08 PM
