JRSC ITR w/particular build questions
Hey guys. Does anyone see any striking issues with the following setup?
b18c5 w/190,000 kms - rebuilt at 170,000 and dyno tuned - runs strong
skunk2 forged valves, retainers, springs (clay tested for clearance)
skunk2 pro stage 2 cams <--- I heard this could be an issue?
spoon adj cam gears (set properly)
jdm itr pistons
new metal headgasket
JR supercharger @ 7.5 psi
hondata intake gasket
walbro 255 fp
440 cc injectors
fuel pressure regulator and gauge
chipped w/Crome engine management and tuned properly on a dyno
Thanks in advance for any constructive comments
jdm itr pistons
walbro 255 fp
440 cc injectors
Re: JRSC ITR w/particular build questions (Andrew Sutherland)
I wouldn't run those cams, too much overlap. GST intake , Type R Exhaust is the best combo we have found to date.
Mr. Badwrench
Re: JRSC ITR w/particular build questions (CRVRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRVRX »</TD></TR><TR><TD CLASS="quote">I wouldn't run those cams, too much overlap. GST intake , Type R Exhaust is the best combo we have found to date.</TD></TR></TABLE>
thats what they said on turbo applications, and people have proved them wrong. but a blower setup is a lot different. depending on where the power is made with the jrsc yes they may hurt you. or they may be great. but setup looks good.
Re: JRSC ITR w/particular build questions (boostedcivicsir)
John knows what he is talking about!
Turbo's are not boost limited like an eaton blower. If you could make 15+psi with them then large duration cams might help out.
Case in point. ITR cams make less hp then the gsr/itr combination with a JRSC.
SOHCVTECx2
09-20-2003 11:53 AM
