Manual boost controller installating
Old Sep 8, 2007 | 06:29 AM
Mr_ET's Avatar
Default Manual boost controller installating
Hi guys,
a bit of a noob question. I search a bit and everyone seems to say that I should run my line off the compressor on the turbo. To do so is it necessary to drill a hole in the compressor and screw in a fitting?
If yes what is the next best alternitive as I don't want to mess with my almost new turbonetics t3/t04e.
Old Sep 8, 2007 | 06:44 AM
Got traction's Avatar
to run a boost controler you need to have the pressure comming from the turbo. so you have to put a nipple on it
Old Sep 8, 2007 | 06:58 AM
Mr_ET's Avatar
Default Re: (Got traction)
so you guys usually yank the turbo off drill and tap the side of the compressor housing, take out all metal chards and bolt it back up?
it's gonna be a pain if I need to take the turbo off lol
Old Sep 8, 2007 | 08:12 AM
Integra_drk's Avatar
Default Re: (Mr_ET)
nearly all turbos ive seen come pre drilled and tapped with a brass fitting for vacuum line.
Old Sep 8, 2007 | 08:15 AM
ndogg's Avatar
Default Re: (Mr_ET)
drill and tap a barb fitting into your chargepipe. put jb weld on the threads and screw it in. that is the next best option.
Old Sep 8, 2007 | 08:12 PM
racin_jayson's Avatar
Hey Mr. ET, I can help you with that in a couple weeks if you want, I have a bunch of extra fittings and the drill bit and tap that is needed. Pm me if your interested, you only have to pop off the compressor housing to do it, it's super easy.
customs-25
Feb 27, 2014 11:51 AM
skaraider
Jun 6, 2012 03:26 AM
hondamonkey
Nov 24, 2007 03:55 PM
Tchleung
Mar 11, 2005 07:44 PM
avividmemory
Sep 6, 2002 06:19 AM
