Blowd Head gasket 2 liter turbo
Hey.
I hope you can give some advice.
I bougth JG Engine dynamic engine. I assemble block and head, I used oem GE overborred 84mm head gasket, arp head studs, I torque 65 torqeu with arp molly.
We out together everthing.
We drove at 5 psi, about 100km. I pull it too 6000 rpm, I did it some times.
It started too leak on the 3 cylinder, the hole road was full off white smoke.
I have good A/F about 12-12.5 and only 5 psi sleeved b18c jdm engine.
managment system is crome.
some idea??
some idea??
Re: Blowd Head gasket 2 liter turbo (Junior_7)
Jg sleeved blocks have been known to never be right. I personally know 2 people who have had sleeves that were messed up and wouldn't seal. Good luck getting them to fix it too.
Re: (WalkerGSR1)
75 psi with the studs. i think i did the oem specs with an additional step to 75. (27,61,75??? i kinda forgot lol). yeah i stripped a headstud nut on the last step. the stud is fine.
anyway ive had similar problems but to a less extent with aebs sleeves. i had the **** decked out of the block and it fixed it. also new oe gasket helped as well with a brand new set of headstuds
Vtec04
Engine Machining & Assembly
11
10-31-2017 09:26 AM
Prelude900
05-10-2015 02:47 PM
