brake problem.
Old Jun 20, 2006 | 12:54 PM
scorpio81's Avatar
Default brake problem.
some times when i brake my brake pedal get real soft and goes all the way down. Then when i release and press again it goes back to normal what could be the problem?
Old Jun 20, 2006 | 01:08 PM
Leo C's Avatar
Night Owl
Default Re: brake problem. (scorpio81)
air in your brake lines
Old Jun 20, 2006 | 02:26 PM
jared99's Avatar
Or master cylinder's bad...that's what's letting in the air
Old Jun 20, 2006 | 03:11 PM
SuzukaBlueAP2's Avatar
Default Re: brake problem. (jared99)
Don't take this problem lightly. Your brakes are VERY important and you should get this solved ASAP.
Start by bleeding the brakes until the pedal pressure is firm. Take it for a little drive. If the pedal still goes down, you may have a leaky MC.
Old Jun 22, 2006 | 05:57 PM
scorpio81's Avatar
Default Re: brake problem. (SuzukaBlueAP2)
ok thanks. But would that make the car pull left or right?
Old Jun 22, 2006 | 06:01 PM
__oversea's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by scorpio81 &raquo;</TD></TR><TR><TD CLASS="quote">ok thanks. But would that make the car pull left or right?</TD></TR></TABLE>
this is another problem. wraped rotor. or un-even wear of pad.
btw: master cylinder is for clutch, booster(big black circle one. next to master cylinder)is what need to be checked.
Old Jun 22, 2006 | 08:29 PM
Sam92Teg's Avatar
Default Re: brake problem. (Last For One)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Last For One &raquo;</TD></TR><TR><TD CLASS="quote">
btw: master cylinder is for clutch, booster(big black circle one. next to master cylinder)is what need to be checked.</TD></TR></TABLE>
Actually, the clutch has its own clutch master cylinder and also a clutch slave cylinder. The clutch master cylinder is next to the brake master cylinder. The brake master cylinder is mounted on the booster. If the brake master cylinder is leaking fluid, it could ruin the booster if enough gets inside. Check the fluid level and look for fluid going down the bottom of the booster and on the fire wall.
If your pulling to one side while braking, it could also be a dragging caliper or one of the two circuits in the master cylinder has failed.
Old Jun 29, 2006 | 02:15 PM
CASTUDILLO01's Avatar
REPLACE THE BRAKE MASTER CYLINDER FIRST DUE TO ITS GOING BAD THEN HAVE TO BLEED ALL THE BRAKE CALIPER AFTER.
Ueichi
Feb 25, 2011 02:25 PM
93b20z
Oct 18, 2008 11:56 AM
blkteggy
Mar 13, 2008 10:14 AM
MrPscott
Dec 2, 2006 06:23 AM
GdmLaz
26
Aug 12, 2005 01:51 AM
