bogging or hesistation problem
Old Jun 22, 2006 | 05:53 AM
Liquidgsr's Avatar
Default bogging or hesistation problem
I recently started to have a problem where my car would hesitate when accelerating in all gears between 1000-2000 rpms. Usually close to 2000 but right before it. The car goes then gets like real slow and doesn't accelerate for a few seconds and suddently jerks and starts going. What could be causing this problem. The car has little over 155k on it. Stock ECU and only I/H/E. I just did a oil change and put some STP oil treatment in when i did the oil change and also put some lucas injector cleaner in. Any ideas?
also got a vafc recently that isn't hooked up yet. I am wondering if I should get the car tuned with that if it will help. Anyone know how much it will run to get it tuned with that?
Modified by Liquidgsr at 8:15 AM 6/22/2006
Old Jun 22, 2006 | 07:28 AM
Lan's Avatar
Lan
Default Re: bogging or hesistation problem (Liquidgsr)
Almost 100% sure it is your catalytic converter. PM'd
Old Jun 22, 2006 | 07:33 AM
thedragon44's Avatar
check timing
Old Jun 22, 2006 | 07:35 AM
Liquidgsr's Avatar
Default Re: (thedragon44)
would the timing go off just like that on its own. I have never messed with the timing or anything like that.
Old Jun 22, 2006 | 07:36 AM
Liquidgsr's Avatar
Default Re: (Liquidgsr)
would there be any signs of the cat going with smoke or something coming out of the exhaust?
Old Jun 23, 2006 | 05:26 AM
Liquidgsr's Avatar
actually i think im noticing it only happens when the car is warm. The idle is now getting lumpy. It drops to where it almost dies and the car shakes a bit then goes backup after a few moments.
Old Jun 23, 2006 | 05:56 AM
petergriffen's Avatar
IACV?
Old Jun 23, 2006 | 06:00 AM
Promina's Avatar
I had the same problem, I had a loose wire on my O2 sensor...
VTECROAR96typeR
May 19, 2009 02:55 AM
MidnightB16
May 14, 2009 11:53 AM
kyorishin
Apr 24, 2006 08:51 AM
93sleeper
Feb 18, 2005 07:23 PM
Jaydeep
Apr 26, 2004 08:43 PM
