Problems with 96 SE Integra - Please Help!
Ok here is the deal. I was driving down the road and all of a sudden i could feel this constant bumpyness coming from the front driver side wheel. It was a constant jabbing up and down up and down and i could feel it right through the floor as i was driving. So i pulled over, checked my tire and it was fine with 42 psi of air in it and no signs of bad wear and all of the lugnuts were tight. I went home checked my brakes and they all seem to be working properly. There is no sign of a warped rotor that i can tell. But the bad part is when it is happening and i go to brake my car pulls to the left and shakes really extremely bad. This goes on for about 5 - 10 miles and then it acts normal. Like today on my way to work it all seemed to work perfectly but on my way home it will probably act up again. Could anyone tell me what is going on here? Or atleast point me in the right direction!? It is much appreciated! Thanks!
Josh R.
Josh R.
I have just the stock tires and rims. The whole car is bone stock! I took the caliper off.... lubed everything up wtih lithium grease and reassembled everything. 2 days later it started to act up again.
I am very confussed!
ok... i lowered it to 30 psi. It doesnt make any noise. My tires look low on air though. It says right on the tires MAX 42 PSI so idk.... I am jsut so confused right now!
