Need some help with my shifter.
Old Feb 28, 2007 | 04:16 PM
jb0705's Avatar
Default Need some help with my shifter.
Wsup Peeps,
Just bought a 92 DA last night, the shifter feels loose. Let me expain;
When your car is on neutral you are able to shif it side to side. When in gears and try to shift it side to side it should feel tight. Well when I put mines in gear any gear you can still shift it side to side just like when it's on neutral. It drives fine just don't understand.
Can someone help.
Old Feb 28, 2007 | 04:39 PM
DraginTeg93's Avatar
Default Re: Need some help with my shifter. (jb0705)
Buy shifter bushings .. You will tell the difference
Old Mar 2, 2007 | 03:35 PM
j_bizach's Avatar
Default Re: Need some help with my shifter. (DraginTeg93)
no not shifter bushing they will help but nine times out of ten its the <U>BEARING</U> that is bad very common problem with older integras
Old Mar 2, 2007 | 05:38 PM
gsR_Ace20's Avatar
Default Re: Need some help with my shifter. (j_bizach)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j_bizach &raquo;</TD></TR><TR><TD CLASS="quote">no not shifter bushing they will help but nine times out of ten its the <U>BEARING</U> that is bad very common problem with older integras </TD></TR></TABLE> also check the shift linkage for a possible loose or missing bolt/nut, mine was doing the same thing on a dc though and it ended up being a freakin 10mm nut that's part of the bracket support. GL
Old Mar 3, 2007 | 04:54 AM
j_bizach's Avatar
Default Re: Need some help with my shifter. (gsR_Ace20)
true had a buddie all of a sudden complain bout his shifter all fucked up. looked underneath and the bolt was bout 5cm from falling completely out. theres a lot of vibraition down ther to losen up the bolt. thats why i use just a dab of locktite as an insurance policy
90dxhatchback
Jun 29, 2005 05:50 PM
HDNBenjamin
Honda Motorcycles
May 27, 2005 10:04 AM
projectej8
Apr 28, 2005 10:26 PM
igo4bmx
12
Sep 4, 2004 09:15 PM
InTeGrA_bLazEd
Oct 5, 2003 04:00 PM
