ecu codes.
Old Feb 26, 2007 | 02:47 PM
sickofitall1113's Avatar
Default ecu codes.
failed inspection. can someone give me the practical names for these codes and what needs to be done about them.
P1456 Evaporative Emissions (EVAP) Control System Leakage (Fuel Tank System)
P1457 Evaporative Emissions (EVAP) Control System Leakage (EVAP Canister System)
P0171 Fuel System Too Lean
i have a 99 ls. thanks
Old Feb 26, 2007 | 02:50 PM
Sumslapper's Avatar
Year 3030
Default Re: ecu codes. (sickofitall1113)
did you take out your charcoal canister? its the cylinder looking thing down below the battery with 2 tubes coming out. one going to the manifold and i cant remember the other
Old Feb 26, 2007 | 06:48 PM
Default Re: ecu codes. (sumslapper)
mmm no i dont think i took out anything. im not even sure what that is. i changed the fuel filter a while back but everything went smoothly with that. any other ideas?
Old Feb 26, 2007 | 09:43 PM
bump
Old Feb 28, 2007 | 11:19 AM
HondaDC4Integra's Avatar
mine had similar problems, minus the fuel. and i drove it for a lil while and it somehow straightened itself out. i am not sayin it will work for you, but it is an idea.
Old Feb 28, 2007 | 11:27 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: ecu codes. (HondaDC4Integra)
the EVAP codes can be caused by an improperly sealed gas cap....there is a rubber o-ring on the inside of the cap that deteriorates over time or can become mis-alligned, and cause that code to be thrown
the system running too lean could correlate back to the vapor canister and link these codes together, however it could also be a segregated code from the EVAP issues.....running too lean means that the o2 sensors are usually in working order and sensing the exhaust mixture is burning off incorrectly
a faulty fuel pressure regulator or any other fuel system issue causing not enough fuel to match the amount of air in combustion will throw this code
Old Mar 8, 2007 | 05:47 PM
Default Re: ecu codes. (GRAF-FITI)
ok well the shop told me to get the stock intake back on there and thats where the codes came from. so i got it from ebay, it came all nice and in working order. i put it back on today, i made sure all clamped areas were tight and disconnected the battery to reset the ECU. 51.3 miles later it comes back on. so im stuck again. should i bring it back to the shop? or try on my own, an ideas?
Old Mar 8, 2007 | 06:08 PM
GRAF-FITI's Avatar
* B A N N E D *
its not your intake...those guys are plain ridiculous for telling you that, and i would find a new mechanic
Old Mar 8, 2007 | 06:16 PM
ok haha. well it only costed like 45 bucks. but yea so what do i need to be looking at. like i have no problem replacing things, i can pretty much do all the work, i have a 60 day rejection sticker so theres no rush.
and the O2 sensor in the header, the front one is new. rear is not and its rusted(molded) onto the cat.
Old Mar 9, 2007 | 06:58 AM
to the top.
Old Mar 9, 2007 | 08:33 AM
ok, possible solution found. small holes, well corrosion on top of charcol canister. thats probably it.
Old Mar 9, 2007 | 01:07 PM
Integra4lyfe069's Avatar
i have the p1457 code too, could u tell me what u did to fix this?
Old Mar 10, 2007 | 06:13 AM
Default Re: ecu codes. (Integra4lyfe069)
FIXED! i put plastic putty stuff over the hole, it hardened and 60 miles later and the CEL isnt on. hooray.
niki1780
Aug 21, 2013 09:19 AM
bighammer
Mar 4, 2013 07:53 AM
BuckeyeRideR
Nov 12, 2009 05:35 PM
danseng28
Aug 18, 2008 04:04 PM
