ve Tapping Up Top
Old Feb 28, 2007 | 05:03 AM
hotinteggy's Avatar
Default ve Tapping Up Top
Does anyone have a slight tapping noise seems to be coming from directly under the valve cover?
Old Feb 28, 2007 | 05:16 AM
Preferio's Avatar
Default Re: ve Tapping Up Top (hotinteggy)
It's common, but how bad is it? Might need your valves adjusted.
Old Feb 28, 2007 | 07:43 AM
hotinteggy's Avatar
Default Re: ve Tapping Up Top (PreFerio)
Its not really bad, noticeable throughout rpm range. It is at its worts upon first startup of the day. I just had to put a set of rod bearings in from leaking head gasket. Problem started shortly after head was done and since i have adjusted the valves.
Old Feb 28, 2007 | 11:57 AM
mike-y's Avatar
what was done to the head?
and what clearance did you use for the lash adjustment?
Old Mar 9, 2007 | 03:21 PM
hotinteggy's Avatar
Default Re: ve Tapping Up Top (mike-y)
I had the head completely gone through checked for cracks etc. Like i said it started off as a rod knocking i replaced the bearings and it got quieter but when u first start it its loud until the OP light goes off then it quiets down but still noticeable. I cant remember the setting i used but i can find it in my book.
mrbassmx
Aug 30, 2013 12:16 PM
noleafclover
Jun 19, 2010 11:57 PM
user 69782342442
Classic Hondas
13
Mar 4, 2009 12:04 AM
Wes90civic
Mar 14, 2004 06:14 PM
danteisme
Feb 9, 2004 09:22 PM
