how to install tach
Old Feb 28, 2007 | 08:21 PM
JDMstatus95's Avatar
Default how to install tach
i want to kno how to install a tach on my coupe with ls swap step by step instructions would be greatly appreciated. thanx
Old Feb 28, 2007 | 08:26 PM
numbnuts22715's Avatar
I definitely know that this can be found from searching in the archives...
Old Feb 28, 2007 | 10:51 PM
i just want to kno what wires go where. ive tried searching but nothing if someone can tell me what wires go where. thanx
Old Feb 28, 2007 | 10:53 PM
i have an autometer sportcomp
Old Mar 1, 2007 | 04:41 AM
DraginTeg93's Avatar
Default Re: (JDMstatus95)
The blue wire on the dizzy and power and ground ..
Old Mar 1, 2007 | 05:51 AM
Tizight's Avatar
I think t-i had a article on it. But, I can't seem to find it right now.
Old Mar 1, 2007 | 05:58 AM
SuzukaBlueAP2's Avatar
Default Re: (Tizight)
The only wires that you'll have to hook up are:
1.) ignition power source
2.) ground
3.) illumination wire (if there is a backlight)
4.) tach signal wire (found either at the ECU or at the distributor. I believe it is green).
If I locate the exact position of the tach signal, I'll post it. All the other wires can be tapped into at the fuse panel under the dash.
Old Mar 1, 2007 | 06:02 AM
Default Re: (SuzukaBlueAP2)
Easy spot to tap for illumination
Use this article for installing a shift light to guide you through the process for installing your tach
Old Mar 1, 2007 | 08:04 AM
Speed94's Avatar
If you look at the driverside firewall in the engine bay you'll see a plug that is there that isnt plugged into anything. Thats one of the tach signal wires. I used that one. You have to clip both loops on the tach as well I believe. The rest is just ignition, ground, and illumination (you can tap into your parking lamp for this)
Old Mar 1, 2007 | 11:58 AM
thanx for the responses very helpful lets hope i dont blow nothing up
EJ8 GSR-T
11
Dec 7, 2004 12:08 PM
DarkBB4
Sep 25, 2004 09:41 PM
Simon Tibbett
Feb 8, 2004 09:22 AM
team2n1hatch
Apr 4, 2003 12:39 PM
91hatchcivic
Aug 1, 2002 11:39 PM
