another cluster problem- with a twist
Old Feb 25, 2007 | 10:07 PM
nate-the-great's Avatar
Default another cluster problem- with a twist
i've spent an hour searching on HT and TI and still can't find a solid answer for my question...
i have a 1994 obd1 gsr.
So I got a gsr cluster on ebay, supposedly out of a 96. My car did not have a cluster in it when I bought it. (Theft recovery). The guy who had it before had a USDM itr cluster in it (probably why it was ripped off).
Heres the problem- plugged it in and open the ignition and the temp and fuel gauges immediately go all the way to the right. I get a lot of lights too- check engine, abs, etc...
from what I've read, it sounds like and obd2 obd1 mismatch problem. Could the guy have lied about the year?
Now i read up on the "swapping green film" solution. The only problem is I don't have a green film to swap with. Is there a wiring diagram on the actual harness so i can modify that? Would that work?
thanks guys
Old Feb 25, 2007 | 10:09 PM
tomithy's Avatar
1996 = odb2
Old Feb 25, 2007 | 10:10 PM
blusmke's Avatar
Default Re: another cluster problem- with a twist (nate-the-great)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nate-the-great &raquo;</TD></TR><TR><TD CLASS="quote">i've spent an hour searching on HT and TI and still can't find a solid answer for my question...
thanks guys</TD></TR></TABLE>if i am not mistaken 96 is a obd2
Old Feb 25, 2007 | 10:16 PM
great.... i thought the cut off was 97. shows my noobness...
is there anyway to re-wire from the harness side so I can use an obd2 cluster and obd2 green film?
Old Feb 25, 2007 | 10:20 PM
blusmke's Avatar
Default Re: (nate-the-great)
i don't know but i have a us and jdm gauge cluster for obd1 if you wanted to buy one
Old Feb 25, 2007 | 10:22 PM
Default Re: (blusmke)
would you consider a trade?
Old Feb 25, 2007 | 10:25 PM
blusmke's Avatar
i am kinda getting rid of all of my car stuff i am done i think
Old Feb 26, 2007 | 09:04 AM
is there anyway to re-wire from the harness side so I can use an obd2 cluster and obd2 green film?</TD></TR></TABLE>
bump???
Old Feb 26, 2007 | 09:19 AM
BlueIntegraBoy's Avatar
Wiring diagram in my sig.
Old Feb 26, 2007 | 09:27 AM
thanks blue integra- one question though.
in the diagrams you have the clusters listed as 94-97, 98-99, and 00-01. If obd2 started in 96, wouldn't the diagram be different between 94 and 97?
Old Feb 27, 2007 | 11:11 AM
i fixed it.
for those searching that have a similar problem, I used blueintegraboy's diagram and compared the pinouts for my year integra. Turns out, the pins for the fuel and temp guage were wired for a 98-99 teg. put them back to 94-97 and it works like a charm. no green film swap.
demonicivis1320
13
Sep 26, 2011 08:26 PM
BokudenNYC
Aug 20, 2008 03:53 PM
Ryan.
Oct 30, 2007 06:46 AM
Double_Dk
Jun 10, 2004 05:32 PM
andrew dc
Apr 29, 2003 07:11 AM
