-------HELP!!--------
i put a new intake on yesterday and i hooked up all the tubes up right but i didnt use any clamps (lost them) but any ways there already really tight as it is ..so once i start my car and go down the street or something i see anti-freeze/coolant and its leaking really bad so can someone help me fix this problem
sounds like you need to check for some llose coolant hoses to the throttle body and the iacv, which is on the back of the mani towards the firewall. prolly knocked someshit loose when you put the intake on
as long as you arnt gushing out tons of coolant....
start the car up with the hood open and try to pin-point where the coolant is coming from. i think its coming from a hose that connects to IACV on the back of the manifold not the EVAP(my bad long day).
yes just check the hoses, there is a hose that you have to disconnect when adding an intake that does carry coolant, go look at what you disconnected and reattach it
when i put on the new intake i put all new hoses on except for one my friend said just keep a small hose on it so can get air(he said thats all it is used for) and this is located towards the end of the hose gluster..ill try and get my girlfriends camera so i can take pics and show you guys soon
