where is main relay locate in?
does anyone know where is main relay location?
im trying to resolder main relay but i cant find where is the main relay.
can anyone show me the pic?
Re: where is main relay locate in? (xkrntamax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xkrntamax »</TD></TR><TR><TD CLASS="quote">does anyone know where is main relay location?
can anyone show me the pic?</TD></TR></TABLE>
The main relay is under the driver's side cowl panel. Basically opposite of where the ECU is, but a bit higher, almost up to the bottom of the dash. You really have to reach up under the panel to get to it. There will be one 10mm bolt holding it onto the body panel. It's tricky to get to....just have to have patience. Use a shorty ratchet with a long extension and swivel socket. That works best from my experience.
http://www.acuraoemparts.com/d...ch=no
You are looking for #17 in the image above. The relay is BIG, you cant miss it. Below is a pic of the actual relay. Hope the info helps.....good luck.
Modified by type_rev at 11:59 AM 3/18/2007
Re: where is main relay locate in? (type_rev)
Can't find any kind of looks like little relay box.
All I see is #21 mounted on the wall.
where is relay.....lol
any more detail pic? please......
Re: where is main relay locate in? (1TurboHatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1TurboHatch »</TD></TR><TR><TD CLASS="quote">#21 is the main relay. </TD></TR></TABLE>
Dude, you're an idiot!! #17 is the main relay. I should know, I sell these parts for an F'ing living. Go smoke some more rock!!!
And to the author of this thread......NO, NO, NO, NO the car won't start with the main relay removed or disconnected!!! Why you ask? Because it controls the current going to the fuel pump, and the current going to the ignition.
Find #17 like I pointed out earlier, and remove it. Then do your soldering thing.
Here's a guide to get you started. This is on a CRX/EF, but it's in basically the same place on an Integra. GOOD LUCK.
http://www.tegger.com/hondafaq/mainrelay.html
Modified by type_rev at 11:56 AM 3/18/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by type_rev »</TD></TR><TR><TD CLASS="quote">
Modified by type_rev at 11:56 AM 3/18/2007</TD></TR></TABLE>
okay i found out main relay but i dont see any problem with that main relay.
The Main Relay will click three times during the starting process. When problems arise, one of those clicks (usually the third) is missing, making those clicks a handy diagnostics tool. If you consistently hear/feel all three clicks, the Relay is fine. DO NOT REPLACE IT.
Turn ignition to ON (but not to START): Click 1
Check Engine light goes off: Click 2
You now turn the key to START: Click 3
but my teg engine light does not goes off.
it usally engine light comes on everyday.., so should i just change main relay?
it usally engine light comes on everyday.., so should i just change main relay?</TD></TR></TABLE>
So your check engine light stays on solid after you crank, and or start the car? If this is the case, your ECU is throwing a code.
1. What year is your Integra?
2. Find out your OBD version.
3. If you can figure that out go to the link below and do some research on how to check your codes.
4. After you find out what code your ECU is throwing, you can narrow down and diagnose the problem.
http://technet.ff-squad.com/how-to/celcheck/
That should get you started.....let me know if you need anymore help.
Modified by type_rev at 10:56 PM 3/18/2007
i went to advance auto part to check engine light
and these are the code that came out from my teg.
P0700
Trans control sys
Malfunction
P0700
Trans control sys
Malfunction
P1753
Manfacurer contrl
transmission
P0758
Shift Solenoid B
Circuit Electrical
P1794
Manfacurer Contrl
Trnas.
and the guy told me nothing wrong with engine starting
P0700
Trans control sys
Malfunction
P0700
Trans control sys
Malfunction
P1753
Manfacurer contrl
transmission
P0758
Shift Solenoid B
Circuit Electrical
P1794
Manfacurer Contrl
Trnas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xkrntamax »</TD></TR><TR><TD CLASS="quote">i went to advance auto part to check engine light
P0700
Trans control sys
Malfunction
P0700
Trans control sys
Malfunction
P1753
Manfacurer contrl
transmission
P0758
Shift Solenoid B
Circuit Electrical
P1794
Manfacurer Contrl
Trnas.
and the guy told me nothing wrong with engine starting</TD></TR></TABLE>
I take it you have an automatic transmission????? You need to find the bad solenoids and replace them.
P0700
Trans control sys
Malfunction
P0700
Trans control sys
Malfunction
P1753
Manfacurer contrl
transmission
P0758
Shift Solenoid B
Circuit Electrical
P1794
Manfacurer Contrl
Trnas.
I take it you have an automatic transmission????? You need to find the bad solenoids and replace them.</TD></TR></TABLE>
Yes AUTOMATIC transmission
how can i replace solenoid?
and i dont know where is that and i dont know what is solenoid.
should i go to collision?
and how much is the solenoid?
