timing issues, need help!!!!
Old Mar 13, 2007 | 02:57 PM
teggyracer91's Avatar
Default timing issues, need help!!!!
my recent post was about an overheating problem. come to find out it was the water pump. i replaced that and the gaskets and now it was time to fire it up. so it wont start now. so i figured that i somehow messed up the timing. i need some help on how to do the timing. can someone please tell me how to time this thing?! thanks.
CJ
Old Mar 13, 2007 | 06:20 PM
92DAturboteg's Avatar
Default Re: timing issues, need help!!!! (teggyracer91)
I could explain it to you but it would be easier for you to search or buy a helms factory service manual. I'll tell you this, if your mechanical timing is so far out that the motor won't start stop trying to crank it... your valves and pistons must be mighty close.
Old Mar 13, 2007 | 06:25 PM
Import_spoon's Avatar
If it doesn't work don;t mess with it because you might bend the valves like me. Unless if your very sure that the teeths are off. Make sure it all the tdc marks line up.
Old Mar 13, 2007 | 09:50 PM
99Geeezer's Avatar
The timing might be off but I hope you are somewhat close because if not, sinced you cranked it over, for your sake I hope the valves aren't bent.
But for informational purposes. put #1 on it's compression stroke. There are a series of marks that need to be lined up(camshafts and crank). once those are lined up, adjust belt tension and you should be dialed.
Old Mar 14, 2007 | 04:40 AM
ok thanks guys ill try to line up all the tdc marks and we'll see wut happens. hopefully the valves arent bent. i only cranked it over a couple of times anyways. i hope its still good.
Terry Langel
Aug 28, 2018 04:19 AM
Jake Bauer
Aug 21, 2017 01:32 PM
EFhatch2403
Apr 29, 2010 01:36 PM
boomersz
Mar 4, 2007 09:09 AM
VIETTEC
May 21, 2006 04:48 AM
