way to test functionality of a solenoid?
Old Mar 13, 2007 | 07:28 AM
sickofitall1113's Avatar
Default way to test functionality of a solenoid?
is there a way to test that other than looking at the device its attached to?
Old Mar 13, 2007 | 07:58 AM
Padawan's Avatar
Darth ModerVader
Default Re: way to test functionality of a solenoid? (sickofitall1113)
Provide the correct voltage to it, and you should hear/see it activate.
Old Mar 13, 2007 | 08:48 AM
JasonST's Avatar
Default Re: way to test functionality of a solenoid? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Provide the correct voltage to it, and you should hear/see it activate.</TD></TR></TABLE>
x2.... Just hook it up to the battery to give it 12 volts.
Old Mar 13, 2007 | 09:10 AM
Default Re: way to test functionality of a solenoid? (JasonST)
ok cool, just did it. it clicked and opened and closed, so its good. now is there any way to check the fuel system, delivery and emissions, for vacuum leaks
Old Mar 13, 2007 | 02:31 PM
ttttop
Old Mar 13, 2007 | 02:42 PM
DeadVet's Avatar
Default Re: (sickofitall1113)
You can use carb cleaner or propane and spray around the lines and such. If the idle changes then thats where your problem is.
Mr. LS VTEC
Oct 15, 2014 05:51 AM
teggy182
Honda Motorcycles
18
Apr 3, 2007 02:09 PM
VTEC-DA
Sep 1, 2003 10:13 PM
jdmcivicferio
Jun 9, 2003 09:49 PM
