weight reduction
Old Mar 11, 2007 | 02:36 PM
401tuner's Avatar
Default weight reduction
i was just wondering what some of you guys were doing for weight reduction, or what can be done to lose some pounds besides stripping the entire interior witch i dident want to do.
Old Mar 11, 2007 | 03:32 PM
98GSRDC2's Avatar
Default Re: weight reduction (401tuner)
lose weight, heat shield, carbon fiber hood and trunk, well a lot of aftermarket stuff
Old Mar 11, 2007 | 05:28 PM
Jack ffr1846's Avatar
There's a ton you can do. Depends on what the car is going to be used for and what you can live without.
I run a racecar that has reasonable weight recution measures, including lexan windows, gutted doors, no interior, heater, bumper beams, headlights and all unused wiring in the car is removed. Sound deadening and undercoating removed. It is NOT street legal and never will be. Saved several hundred pounds.
For the street, there are knee bolsters under the dash....steel plate backings under the covers, bumper beams, associated brackets replaced by tie wraps, radio and speakers and associated wiring.
For the most part, carbon fibre hoods for the street are as heavy as a steel one or heavier. I've measured ones for my CRX and they're quite a bit heavier than my steel one with the latch and internal bracing removed.
jack
Old Mar 11, 2007 | 05:46 PM
Bignel00's Avatar
abs module(get rs brake lines , rs proportion valve, rs master cylnder), ac compressor, power steering , get ur *** on a tread mill thats wha i did.lol
Old Mar 11, 2007 | 05:54 PM
92DAturboteg's Avatar
Default Re: weight reduction (Bignel00)
pull up your carpet and chip out the sound deadening materisl, there is at least 20lbs under there.
Old Mar 11, 2007 | 06:43 PM
401tuner's Avatar
Default Re: weight reduction (Jack ffr1846)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jack ffr1846 &raquo;</TD></TR><TR><TD CLASS="quote">. For the street, there are knee bolsters under the dash....steel plate backings under the covers, bumper beams, associated brackets replaced by tie wraps, radio and speakers and associated wiring.</TD></TR></TABLE>
no **** i dident kno a lot of this stuff, But yea what knee bolsters under the dash are you tlaking about and the steel plate backing, and witch bumper beams. And with removing stuff like this how much weight do you think it will take off? and how much does a stock gsr weight like 2600?
Old Mar 12, 2007 | 10:33 AM
There's a ton of stuff that you can remove if you only knew it was there to begin with. I own a CRX racecar that's been stripped to 1600 pounds, and am buying cars to get a swap for cheap by selling off the parts. The knee bolsters I found were in a DA but I expect the DC's probably still carried them through. One was behind the panel below the steering wheel and the other on the pass side behind another plastic panel. Bumper beams are the actual steel structures that take the hit if someone hits you hard enough to push past the bumper cover and styrofoam that's under it. I'd say each bumper beam is maybe 8 pounds. Then you can continue to bumper supports and their mounts and bolts. Maybe another 5 pounds per end of the car. The bumper will still stay in place without it but you might have to make a bracket for the rear.
With any of these removals, you've got to decide for yourself if you want to give up whatever structure they provide. You would need to do a bunch of searching around your car and decide what you're willing to take out and what needs to stay in place.
In a racecar, it's a given that you want everything out that you can possibly get out. Spending 25-30 hours removing unwanted wiring in the car is a given. Finding all of the extra tabs and brackets in the car and cutting them off is a given. Spending 20 hours removing undercoating and another 20 removing sound deadening is a given.
If you want to be less radical, as an example, I removed 150 pounds from a Subaru 2.5RS (GC8) when I was running my street car on the track. This was all in simple stuff that was not needed for the car to go fast. Scoop and block off plate, vent block off plates, wing, brake backing plates, the subaru had 2 bricks....one inside the glove box door and one on the engine/tranny bracket. It takes a bunch of snooping and 3 ounces here, a half pound there. There's no 100 pound big thing to get rid of, unfortunately.....at least that I know of.
The Fox Mustang guys have it easy, to some extent. There's a huge....like 15-20 pound steel piece on the rear end. It's there to get rid of harmonic noises at certain speeds. I've never found anything that huge on any other car.
jack
Old Mar 13, 2007 | 09:27 AM
ALL MOTOR DOHC VTEC's Avatar
From: mathematical with a pistol i do trigonometry, CA, U.S.
Default Re: weight reduction (98GSRDC2)
yep
Old Mar 13, 2007 | 09:33 AM
.brian.'s Avatar
eat more fiber. exercise regularly. eat more fruits and vegetables.
Old Mar 13, 2007 | 09:49 AM
codenamezero's Avatar
read this
http://www.team-integra.net/fo...34874
Old Mar 13, 2007 | 11:33 AM
401tuner's Avatar
Default Re: (codenamezero)
nice thanks guys
Old Mar 13, 2007 | 12:30 PM
b20acura's Avatar
Default Re: (.brian.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .brian. &raquo;</TD></TR><TR><TD CLASS="quote">eat more fiber. exercise regularly. eat more fruits and vegetables. </TD></TR></TABLE>
haha you beat me to it
Old Mar 13, 2007 | 01:53 PM
Pee Wee's Avatar
Default Re: (b20acura)
the glove box is somewhat heavy
Old Mar 13, 2007 | 02:37 PM
.brian.'s Avatar
go big or go home
http://www.sportcompactcarweb....ogram/
Old Mar 13, 2007 | 02:45 PM
mike9571's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .brian. &raquo;</TD></TR><TR><TD CLASS="quote">go big or go home
Holy hell if he was to crash he'd be DEAD!
Old Mar 13, 2007 | 02:56 PM
Tibu_teggy's Avatar
No ****
Old Mar 13, 2007 | 03:15 PM
Blahblah718293's Avatar
Default Re: (Tibu_teggy)
never fill up past 1/4 tank.. that should save some good weight.
Old Mar 13, 2007 | 03:47 PM
Lokisdope's Avatar
get a geo metro
Old Mar 13, 2007 | 03:56 PM
b20acura's Avatar
Default Re: (Lokisdope)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lokisdope &raquo;</TD></TR><TR><TD CLASS="quote">get a geo metro</TD></TR></TABLE>
haha get a bike
Old Mar 13, 2007 | 04:36 PM
GRAF-FITI's Avatar
* B A N N E D *
no fat chicks
Old Mar 13, 2007 | 05:10 PM
Moogen Powah's Avatar
Default Re: (GRAF-FITI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401tuner &raquo;</TD></TR><TR><TD CLASS="quote">i was just wondering what some of you guys were doing for weight reduction, or what can be done to lose some pounds besides stripping the entire interior witch i dident want to do. </TD></TR></TABLE>
What's your purpose in reducing weight?
Old Mar 13, 2007 | 05:18 PM
PrinceAli132's Avatar
Default Re:
http://www.team-integra.net/fo...earch
Ali
Old Mar 13, 2007 | 05:43 PM
ejmatzell's Avatar
Default Re: weight reduction (ALL MOTOR DOHC VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL MOTOR DOHC VTEC &raquo;</TD></TR><TR><TD CLASS="quote">yep</TD></TR></TABLE>
wtf?
Old Mar 13, 2007 | 06:17 PM
Sam92Teg's Avatar
Default Re: (mike9571)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike9571 &raquo;</TD></TR><TR><TD CLASS="quote">
Holy hell if he was to crash he'd be DEAD!</TD></TR></TABLE>
Anyone notice that he is also running on a donut?
CarGuy37
Welding / Fabrication
Oct 30, 2006 06:23 AM
importboi22
35
Feb 3, 2005 08:39 AM
jrfender
Feb 10, 2003 06:41 AM
Briman2021
11
Aug 20, 2002 10:48 AM
