tach. - which wire?
Old Mar 14, 2007 | 06:09 PM
teddy_dc2's Avatar
Default tach. - which wire?
have an autometer tach, which wire is it on the distributor? or another closer?
Old Mar 14, 2007 | 08:19 PM
pdotjones's Avatar
Default Re: tach. - which wire? (teddy_dc2)
i believe its the green one.....
found this on ti
Black = ground
Red = 12v source when the key is on
White = 12v lighting
Green = tach. signal.
Pretty simple .
Old Mar 14, 2007 | 09:06 PM
BG-Teg's Avatar
Default Re: tach. - which wire? (pdotjones)
the one to the dizzy is most likley the longest out of the bunch because it has to reach the farthest
Old Mar 14, 2007 | 11:02 PM
53JDMDC2's Avatar
Auto meter tach leads are usually green. where are your instructions?
GREEN
Old Mar 14, 2007 | 11:54 PM
veth's Avatar
in the back if the guages there 3 clips of wiring ....the clip on the left , theres a blue wire ....that wire is the signal for ur stock tach ...
Old Mar 14, 2007 | 11:59 PM
BlueIntegraBoy's Avatar
Run it to the negative side of the coil OR tap the solid blue wire from the cluster harness
Old Mar 15, 2007 | 05:26 AM
teddy_dc2's Avatar
yes i know the wire color codes that are coming from the tach, i was just wondering where i can hook the green wire from the tach to? my buddy tapped it with one of the wires to the distributor last time but i replace my head gasket and forgot where it goes. is there another wire closer i can tap it to? it's for a gsr of corse..
Old Mar 15, 2007 | 06:41 AM
94_DC4's Avatar
Default Re: (teddy_dc2)
The tach wire for the car is blue which could be found on the distributor plug or behind the cluster. But please test the wire just to confirm. Send me a PM if you need any help.
Old Mar 15, 2007 | 07:02 PM
teddy_dc2's Avatar
thanks
Tyson
40
Jun 4, 2009 04:24 PM
esean93
Aug 23, 2008 10:33 AM
slimjimdanny
Jan 31, 2007 07:35 PM
bbhockey19
10
Jul 11, 2006 09:10 PM
YellowCRXSi
Jul 12, 2004 09:55 PM
