ITR 5 lug conversion
Old Mar 11, 2007 | 05:46 AM
LoNgHoRn's Avatar
Default ITR 5 lug conversion
Hi peeps...I have an LS and swapped a 5 lugger from an ITR..after bleeding, I noticed that my pedal is a little deep than normal...do I have to change my proportioning valve or my master cylinder?? Please advise...thanks!!
PS: Done searching but to no avail....
Old Mar 11, 2007 | 10:24 AM
BlueIntegraBoy's Avatar
Default Re: ITR 5 lug conversion (LoNgHoRn)
Your prop valve is fine. I'd upgrade to a 98-01 1" MC if you don't have one already.
Old Mar 11, 2007 | 10:38 AM
LoNgHoRn's Avatar
Default Re: ITR 5 lug conversion (BlueIntegraBoy)
Thanks bro...from what particular car can I get a 1" MC that will fir the one I had in my LS??
Old Mar 11, 2007 | 10:59 AM
Dogginator's Avatar
Daisy... Daisy...
If the car has ABS, it already has a 1" master cylinder. Only the RS had a smaller master cylinder. The 98-01 master cylinders will not fit your car without major modifications to the brake lines.
Keep bleeding. Bleed the rears and then the fronts. You will need to repeat this cycle several times.
Old Mar 11, 2007 | 11:04 AM
LoNgHoRn's Avatar
Default Re: ITR 5 lug conversion (Dogginator)
it's non abs bro..anyway...i'll bleed it again and hope it will turn ou okay..will let you know...thanks!
Old Mar 11, 2007 | 11:07 AM
Dogginator's Avatar
Daisy... Daisy...
What year is your car? The size of the master cylinder should be stamped on it as well.
jetspeedz
Suspension & Brakes
Sep 18, 2012 04:01 AM
dabomb
Jul 12, 2005 06:33 PM
Demented
Feb 25, 2005 09:14 AM
EricUSC
20
Jan 29, 2003 07:26 PM
