Too good to be true??
Hey, so my friend is thinking about getting this for his
LS teg,
it's 1500 bux,
seems like an amazing deal.
just wanted to see what you guys thought about it.
he's got a 94 LS bonestock.
im trying to sell my longblock...... asking $1500.....no lower.....i spent $800 on the block alone....
NO TRADES NO LOWBALLER
only 5k on rebuilt block...run wit 91 octane gas and Moble 1 oil
its an OBD2b motor, it runs good with no problem.......can be test drive before purchase..
b18c1 block
81.50mm bore
new itr p73 piston, rings, pins
reconditioned rods
micropolished crank
honed and resurfaced
New oem clutch and flywheel--grabs really good--
oil pan
has VIN # on it.....will prove with paper work from CHP
b16a2 head ( 62k ) clean
AEM cam gears
new Gator timing belt
new honda head gasket 81.50mm
stock intake mani/TB complete
AEM short ram intake Carb legal
NGK wires and platinum plugs
obd2 Dizzy
what it comes with :
OBD1 v-tec harness
shift linkage
what it doesnt come with :
axles, mounts, ecu, alternator, ps, ac
LS teg,
it's 1500 bux,
b18c1 block
81.50mm bore
reconditioned rods
micropolished crank
oil pan
AEM cam gears
obd2 Dizzy
OBD1 v-tec harness
shift linkage
Well it might be legit, seeing as he's probably selling it for less because it's not complete. When he goes to check out the car, ask for reciepts for everything. Check VIN's. Other than that idk.
doubleA
Dec 1, 2007 11:58 PM
