Steering Problems?????
Old Mar 11, 2007 | 12:58 AM
sleeperrex's Avatar
Default Steering Problems?????
so this is for my friend. He has a 95 Integra Rs. It hit a curb like a few months ago on the right side, and he fixed the body damage, but since then turning right isn't right.
i can bust a U on his car turning left, but cant bust a U on his car turning right. It feels as if it wont turn all the was right. We jacked the car up and took a look at it and it SEEMS normal under there
Could this be a steering rack problem??
Old Mar 11, 2007 | 10:50 AM
Sam92Teg's Avatar
Default Re: Steering Problems????? (sleeperrex)
An alignment shop should be able to tell you the parts that are causing the problem. Something is probably bent.
Old Mar 11, 2007 | 01:37 PM
sleeperrex's Avatar
Default Re: Steering Problems????? (Sam92Teg)
yea i told me friend why didnt he ask wat was wrong....cuz they told him it was $600 dollars to fix everythin...labor + parts
Old Mar 11, 2007 | 03:16 PM
sleeperrex's Avatar
his right side is messed up...they cant set the toe to 0 in the front or rear
Old Mar 11, 2007 | 04:50 PM
99Geeezer's Avatar
Maybe a 600 dollar qoute from a shop suggest some mecanical problems. Something an alignment cannot fix.
Old Mar 11, 2007 | 07:38 PM
sleeperrex's Avatar
Default Re: Steering Problems????? (99Geeezer)
anyone?
Old Mar 11, 2007 | 09:27 PM
redDAinteg's Avatar
You should posy some pictures. He could have bent control arms, sway bar, axle might be bad, the entire rear trailing arm could be bent or the worst, a bent frame. But we dont know anything until we can at least see pictures.
Old Mar 11, 2007 | 10:13 PM
99Geeezer's Avatar
Default Re: Steering Problems????? (redDAinteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redDAinteg &raquo;</TD></TR><TR><TD CLASS="quote">You should posy some pictures. He could have bent control arms, sway bar, axle might be bad, the entire rear trailing arm could be bent or the worst, a bent frame. But we dont know anything until we can at least see pictures.</TD></TR></TABLE>
X2
Jon Petersen
Sep 16, 2017 12:17 AM
RSX523
May 22, 2008 09:09 PM
92integraVTECgsr
Nov 22, 2005 03:50 PM
preludacris22
Sep 15, 2004 09:57 AM
S.Celia
Dec 8, 2003 04:46 PM
